Zum Hauptinhalt wechseln
Le Pan II Charging Port Replacement
Kelly Moniz
Kelly Moniz und eine weitere beteiligte Person
Zuletzt aktualisiert am February 23, 2019
15 Minuten
Mittel
Falsche Werkzeuge
In this guide, you will be shown step-by-step how to replace your Le Pan II charging port.
Was du brauchst
Werkzeuge
Mehr anzeigen …
  1. Le Pan II Charging Port Replacement, Screen: Schritt 1, Bild 1 von 2 Le Pan II Charging Port Replacement, Screen: Schritt 1, Bild 2 von 2
    • Insert metal spudger between front and back panel to pry apart.
    • Continue to pry while moving the metal spudger along the crevice to completely separate two panels.
    • Avoid using metal when opening devices, as it can damage or crack the screen.
  2. Le Pan II Charging Port Replacement: Schritt 2, Bild 1 von 2 Le Pan II Charging Port Replacement: Schritt 2, Bild 2 von 2
    • Use the plastic opening tool to disconnect the flat ribbon cable from the motherboard connector.
    • Disconnect the flat ribbon by gently pulling it out from its connecting port.
  3. Le Pan II Charging Port Replacement: Schritt 3, Bild 1 von 2 Le Pan II Charging Port Replacement: Schritt 3, Bild 2 von 2
    • Use the plastic opening tool to disconnect the display cable from its motherboard connector.
    • Disconnect the display cable by gently pulling it out from its connecting port.
  4. Le Pan II Charging Port Replacement: Schritt 4, Bild 1 von 1
    • Remove grey metal backing from screen.
  5. Le Pan II Charging Port Replacement: Schritt 5, Bild 1 von 1
    • Flip the tablet so the screen is facing upward, and use the metal spudger to pry apart the screen from the side pieces.
  6. Le Pan II Charging Port Replacement: Schritt 6, Bild 1 von 1
    • Lift and carefully remove the LCD display from the front cover.
  7. Le Pan II Charging Port Replacement, Charging Port: Schritt 7, Bild 1 von 1
    • Use the Phillips 00 screwdriver head to unscrew the screws to the motherboard.
    • Reminder: There should be 8 (3.5 mm) screws to the motherboard.
  8. Le Pan II Charging Port Replacement: Schritt 8, Bild 1 von 1
    • Use the Phillips 00 screwdriver head to unscrew the screws to the fan.
    • Reminder: There should be 4 (1mm) screws to the fan.
  9. Le Pan II Charging Port Replacement: Schritt 9, Bild 1 von 1
    • Use the metal spudger to pry off the charging port from the motherboard.
Abschluss
Kelly Moniz
525 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team 6-3, Martin Fall 2016 Mitglied von UMass Dartmouth, Team 6-3, Martin Fall 2016
UMASSD-MARTIN-F16S6G3
3 Mitglieder
10 Anleitungen geschrieben
Ein Kommentar
I have had no luck getting in touch with anyone in the customer service department.I have left several messages but have not heard from anyone yet. I just need to know how I can get a charge port for my daughters tablet. She had it 6 months before the charge port went out.
tashiarmarshall - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 1,243
