Zum Hauptinhalt wechseln
Lenovo Horizon 2s Rear Case Replacement
Zak Kazakos
Zak Kazakos und 3 weitere Mitwirkende
Zuletzt aktualisiert am October 19, 2018
15 Minuten
Mittel
Use this guide to remove the rear case, which is designed to prevent damage to interior components.
This guide will provide step-by-step instructions on how to access the internal components.
Was du brauchst
Ersatzteile
Werkzeuge
Mehr anzeigen …
iFixit erhält eine Provision, wenn du über diese Links etwas kaufst.
  1. Lenovo Horizon 2s Rear Case Replacement, Rear Case: Schritt 1, Bild 1 von 3 Lenovo Horizon 2s Rear Case Replacement, Rear Case: Schritt 1, Bild 2 von 3 Lenovo Horizon 2s Rear Case Replacement, Rear Case: Schritt 1, Bild 3 von 3
    • Flip the device so the rear case is facing upward.
    • With the plastic opening tool carefully pry the plastic piece shown in the picture, until it is completely removed from the case.
  2. Lenovo Horizon 2s Rear Case Replacement: Schritt 2, Bild 1 von 2 Lenovo Horizon 2s Rear Case Replacement: Schritt 2, Bild 2 von 2
    • Using your fingers, carefully remove the rubber boot from the right side of the rear case.
    • With the Phillips #1 head, remove the screw placed directly under the rubber boot.
  3. Lenovo Horizon 2s Rear Case Replacement: Schritt 3, Bild 1 von 1
    • Using the plastic opening tool, push the display screen on the device forward until it separates from the rear casing.
  4. Lenovo Horizon 2s Rear Case Replacement: Schritt 4, Bild 1 von 1
    • Using the plastic opening tool, carefully pry around the perimeter of the screen until the entire screen is completely separated from the rear casing.
  5. Lenovo Horizon 2s Rear Case Replacement: Schritt 5, Bild 1 von 3 Lenovo Horizon 2s Rear Case Replacement: Schritt 5, Bild 2 von 3 Lenovo Horizon 2s Rear Case Replacement: Schritt 5, Bild 3 von 3
    • Before completely separating the screen from the rear casing you will carefully detach two wires that are connected to both sides of the device. This will allow you to completely separate the rear casing from screen.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Zak Kazakos
320 Reputation
3 Anleitungen geschrieben
USF Tampa, Team S3-G6, Cannon Fall 2017 Mitglied von USF Tampa, Team S3-G6, Cannon Fall 2017
USFT-CANNON-F17S3G6
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 1,039
