Zum Hauptinhalt wechseln
Lenovo Horizon 2s Speaker Replacement
Zak Kazakos
Zak Kazakos und 4 weitere Mitwirkende
Zuletzt aktualisiert am July 27, 2021
20 Minuten
Mittel
Fehler in den Markups
Use this guide to replace faulty speakers in your two-in-one tablet.
This guide will also provide step-by-step instruction on how to detach the back panel, which is designed to prevent damage to interior components.
Was du brauchst
Werkzeuge
  1. Lenovo Horizon 2s Speaker Replacement, Rear Case: Schritt 1, Bild 1 von 3 Lenovo Horizon 2s Speaker Replacement, Rear Case: Schritt 1, Bild 2 von 3 Lenovo Horizon 2s Speaker Replacement, Rear Case: Schritt 1, Bild 3 von 3
    • Flip the device so the rear case is facing upward.
    • With the plastic opening tool carefully pry the plastic piece shown in the picture, until it is completely removed from the case.
  2. Lenovo Horizon 2s Speaker Replacement: Schritt 2, Bild 1 von 2 Lenovo Horizon 2s Speaker Replacement: Schritt 2, Bild 2 von 2
    • Using your fingers, carefully remove the rubber boot from the right side of the rear case.
    • With the Phillips #1 head, remove the screw placed directly under the rubber boot.
  3. Lenovo Horizon 2s Speaker Replacement: Schritt 3, Bild 1 von 1
    • Using the plastic opening tool, push the display screen on the device forward until it separates from the rear casing.
  4. Lenovo Horizon 2s Speaker Replacement: Schritt 4, Bild 1 von 1
    • Using the plastic opening tool, carefully pry around the perimeter of the screen until the entire screen is completely separated from the rear casing.
  5. Lenovo Horizon 2s Speaker Replacement: Schritt 5, Bild 1 von 3 Lenovo Horizon 2s Speaker Replacement: Schritt 5, Bild 2 von 3 Lenovo Horizon 2s Speaker Replacement: Schritt 5, Bild 3 von 3
    • Before completely separating the screen from the rear casing you will carefully detach two wires that are connected to both sides of the device. This will allow you to completely separate the rear casing from screen.
  6. Lenovo Horizon 2s Speaker Replacement, Speaker: Schritt 6, Bild 1 von 2 Lenovo Horizon 2s Speaker Replacement, Speaker: Schritt 6, Bild 2 von 2
    • Locate the intertwined black and red wires that connect the two small, black speakers and the motherboard, as shown in the picture.
    • Disconnect this wire from the motherboard by carefully pulling it out.
  7. Lenovo Horizon 2s Speaker Replacement: Schritt 7, Bild 1 von 3 Lenovo Horizon 2s Speaker Replacement: Schritt 7, Bild 2 von 3 Lenovo Horizon 2s Speaker Replacement: Schritt 7, Bild 3 von 3
    • Locate the speakers along the bottom of the device.
    • The speakers are connected by two knobs on each side. Carefully lift the speakers to detach them from the tablet.
  8. Lenovo Horizon 2s Speaker Replacement: Schritt 8, Bild 1 von 1
    • Finally, locate the tape that keeps the speaker wires in the grooves of the device.
    • Peel the tape off as shown and your speakers are now completely disconnected from the tablet.
Abschluss
Zak Kazakos
320 Reputation
3 Anleitungen geschrieben
USF Tampa, Team S3-G6, Cannon Fall 2017 Mitglied von USF Tampa, Team S3-G6, Cannon Fall 2017
USFT-CANNON-F17S3G6
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 297
