Lenovo IdeaPad 3-14IIL05 Cooling Fan Replacement
Einleitung
Zu Schritt 1 der AnleitungUse this guide to replace the cooling fan in the Lenovo IdeaPad 3-14IIL05 laptop.
The cooling fan is in charge of regulating the temperature of the laptop. If your laptop is overheating, consider cleaning or upgrading the cooling fan.
Was du brauchst
Werkzeuge
Flip the laptop with the screen side facing down and the back panel facing you.
Remove the six 1.2 mm screws and the four 0.6 mm screws using a Phillips #1 screwdriver.
Remove the single screw from the Wi-Fi card.
Detach the wires from the Wi-Fi card.
