Zum Hauptinhalt wechseln
Lenovo IdeaPad Flex 5 14ARE05 Touchpad Replacement
Jonathan Baldo
Jonathan Baldo und 3 weitere Mitwirkende
Zuletzt aktualisiert am December 30, 2024
30 Minuten
Mittel
Anleitung eines Community-Mitglieds
This is a touchpad removal guide for the Lenovo IdeaPad Flex 5 14ARE05. The touchpad is the built-in device that's responsible for your mouse input to the laptop. In this guide, you will remove the back panel, battery, and motherboard to reach the touchpad. If your touchpad is not functional or needs to be replaced for any other reason, use this guide. Make sure the laptop is powered down and disconnected from all power sources.
Was du brauchst
Werkzeuge
Mehr anzeigen …
  1. Lenovo IdeaPad Flex 5 14ARE05 Touchpad Replacement, Back Panel: Schritt 1, Bild 1 von 2 Lenovo IdeaPad Flex 5 14ARE05 Touchpad Replacement, Back Panel: Schritt 1, Bild 2 von 2
    • Remove the five 8 mm screws using a T5 Torx Screwdriver.
    • Remove the four 5 mm screws using a T5 Torx Screwdriver.
  2. Lenovo IdeaPad Flex 5 14ARE05 Touchpad Replacement: Schritt 2, Bild 1 von 3 Lenovo IdeaPad Flex 5 14ARE05 Touchpad Replacement: Schritt 2, Bild 2 von 3 Lenovo IdeaPad Flex 5 14ARE05 Touchpad Replacement: Schritt 2, Bild 3 von 3
    • Use a small suction cup to pull open the back case at the two hinge cutouts.
    • Gently, use the plastic opening tool around the edges of the laptop to pry up the rest of the back panel.
  3. Lenovo IdeaPad Flex 5 14ARE05 Touchpad Replacement: Schritt 3, Bild 1 von 1
    • Once all the clips have been disengaged, lift off the back cover.
  4. Lenovo IdeaPad Flex 5 14ARE05 Touchpad Replacement, Battery: Schritt 4, Bild 1 von 2 Lenovo IdeaPad Flex 5 14ARE05 Touchpad Replacement, Battery: Schritt 4, Bild 2 von 2
    • Remove the four 5 mm Phillips #00 screws that secure the battery in place.
  5. Lenovo IdeaPad Flex 5 14ARE05 Touchpad Replacement: Schritt 5, Bild 1 von 2 Lenovo IdeaPad Flex 5 14ARE05 Touchpad Replacement: Schritt 5, Bild 2 von 2
    • Rotate the device 90 degrees.
    • Gently lift up on the battery and use a spudger to disconnect the battery connector.
  6. Lenovo IdeaPad Flex 5 14ARE05 Touchpad Replacement, Cooling Fan: Schritt 6, Bild 1 von 1
    • Remove the four 2 mm screws using a JIS #1 screwdriver.
    • Remove the three 5 mm screws using a JIS #1 screwdriver.
  7. Lenovo IdeaPad Flex 5 14ARE05 Touchpad Replacement: Schritt 7, Bild 1 von 3 Lenovo IdeaPad Flex 5 14ARE05 Touchpad Replacement: Schritt 7, Bild 2 von 3 Lenovo IdeaPad Flex 5 14ARE05 Touchpad Replacement: Schritt 7, Bild 3 von 3
    • Unplug the wire at the bottom right of the fan.
    • Carefully lift the fan from its place.
  8. Lenovo IdeaPad Flex 5 14ARE05 Touchpad Replacement, Touchpad: Schritt 8, Bild 1 von 1
    • Pull on the blue tab to disconnect the large ribbon cable.
    • Pull on the blue tab to disconnect the small ribbon cable.
  9. Lenovo IdeaPad Flex 5 14ARE05 Touchpad Replacement: Schritt 9, Bild 1 von 1
    • Use the spudger to disconnect the speaker plug on the right of the motherboard.
    • Pull the speaker towards you and it will disconnect from its mount.
    • Pull up on the Wi-Fi card wire connections, and move them aside.
  10. Lenovo IdeaPad Flex 5 14ARE05 Touchpad Replacement: Schritt 10, Bild 1 von 1
    • Remove the four 4 mm motherboard screws with a Phillips #1 screwdriver.
  11. Lenovo IdeaPad Flex 5 14ARE05 Touchpad Replacement: Schritt 11, Bild 1 von 1
    • Remove the two 2 mm screws from the right hinge using a Phillips #2 screwdriver.
    • Disconnect the screen cable connector.
    • Remove the motherboard from the laptop.
  12. Lenovo IdeaPad Flex 5 14ARE05 Touchpad Replacement: Schritt 12, Bild 1 von 1
    • Remove the four 2 mm screws from the touch-pad bracket using a Phillips #0 screwdriver.
    • Pull the bracket up and out of the frame of the laptop.
Abschluss
Jonathan Baldo
319 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team 1-6, Konn Fall 2024 Mitglied von UMass Dartmouth, Team 1-6, Konn Fall 2024
UMASSD-KONN-F24S1G6
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 9
Letzte 30 Tage: 55
Insgesamt: 135
