Lenovo Miix 2 Battery Replacement
Einleitung
Zu Schritt 1 der AnleitungThis guide explains how to quickly open the back case of the Miix 2 using spudgers and a screwdriver.
Was du brauchst
Remove the back cover of the tablet by inserting a nylon or metal spudger in the small hole between the screen and rear cover near the volume button. Slide the tool along the edge of the tablet to release the internal clasps.
Unscrew the six 3mm screws surrounding the battery dock using a Phillips #0 screwdriver.
Using a plastic spudger, slowly push each side of the battery connector (back and forward a couple of times) out of its socket on the motherboard.
3 weitere Personen haben diese Anleitung absolviert.
