Lenovo ThinkPad T400s LCD Screen Replacement
Einleitung
Zu Schritt 1 der AnleitungThe LCD screen and its peripherals are very sensitive and mishandling may result in a missing dot, line, or pixel problems. To ensure that no damage is done to the LCD screen:
- Don't apply pressure to the LCD
- Always hold the LCD from the right and left edges
- Don't apply any pressure to the lower part of the LCD
Was du brauchst
Use a #0 Phillips head screwdriver to remove the two 3mm screws that hold the screen bezel in place.
Using the plastic opening tool, gently pry off the plastic LCD screen frame around the entire perimeter.
7 weitere Personen haben diese Anleitung absolviert.
