Zum Hauptinhalt wechseln
Lenovo ThinkPad X1 Carbon (2nd Gen) Battery Replacement
Eevee Murdock
Eevee Murdock und 2 weitere Mitwirkende
Zuletzt aktualisiert am June 3, 2024
8 - 10 Minuten
Leicht
If your Lenovo ThinkPad X1 Carbon (2nd Gen) won’t turn on or last the full battery life, use this guide to replace the battery.
The battery stores the energy for your computer.
Before using this guide, check that your computer has been charged in a reliable outlet by trying multiple outlets. Also, try using multiple charging cords to make sure your cord isn’t broken.
Before you begin, make sure your computer is off and unplugged.
Was du brauchst
Fix Kit
Dieses Kit enthält alle Ersatzteile und Werkzeuge, die für die Anleitung benötigt werden.
Ersatzteile
Werkzeuge
Mehr anzeigen …
  1. Lenovo ThinkPad X1 Carbon (2nd Gen) Battery Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Using a Phillips #0 screwdriver, remove the seven 7mm screws holding the back cover onto your computer.
  2. Lenovo ThinkPad X1 Carbon (2nd Gen) Battery Replacement: Schritt 2, Bild 1 von 2 Lenovo ThinkPad X1 Carbon (2nd Gen) Battery Replacement: Schritt 2, Bild 2 von 2
    • Use a plastic opening tool or your fingers to pry off the cover.
  3. Lenovo ThinkPad X1 Carbon (2nd Gen) Battery Replacement, Battery: Schritt 3, Bild 1 von 2 Lenovo ThinkPad X1 Carbon (2nd Gen) Battery Replacement, Battery: Schritt 3, Bild 2 von 2
    • Using your fingers, disconnect the battery from the motherboard.
  4. Lenovo ThinkPad X1 Carbon (2nd Gen) Battery Replacement: Schritt 4, Bild 1 von 1
    • Using a Phillips #0 screwdriver, unscrew the five 4.3mm screws attaching the battery to the computer.
  5. Lenovo ThinkPad X1 Carbon (2nd Gen) Battery Replacement: Schritt 5, Bild 1 von 1
    • Remove the battery by pulling it directly towards you.
Abschluss
9 weitere Personen haben diese Anleitung absolviert.
Eevee Murdock
1.110 Reputation
6 Anleitungen geschrieben
Cal Poly, Team S18-G4, White Winter 2020 Mitglied von Cal Poly, Team S18-G4, White Winter 2020
CPSU-WHITE-W20S18G4
4 Mitglieder
9 Anleitungen geschrieben
4 Kommentare
iFixit replacement battery is rejected by X1 Carbon gen2 chassis as not-genuine/unauthorized. Is there some additional step to getting the battery to be recognized/allowed? Something in the BIOS? Or is the battery faulty?
lenovo_battery - Antwort
Any comments from @ifixit?
Martin Optilon - Antwort
Hi there! Thanks for bringing this to our attention. @lenovo_battery, sorry to hear you're having trouble with your battery. Please reach out directly to our customer support team by emailing support@ifixit.com.
Kristen Gismondi -
Hi,
Great guide. I found that my screw heads were a bit stripped and the #0 driver was too small and bounced too much. The #1 driver worked better for me. Thanks for promoting the repair revolution! - MiLo
milostudios - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 19
Letzte 30 Tage: 91
Insgesamt: 5,756
