Zum Hauptinhalt wechseln
Lenovo Thinkpad E540 Display Screen Replacement
Timothy Sumner
Timothy Sumner und 4 weitere Mitwirkende
Zuletzt aktualisiert am June 21, 2018
10 - 20 Minuten
Leicht
A guide on how to replace the scree on a Lenovo ThinkPad E540 laptop.
Was du brauchst
Werkzeuge
  • Phillips #00 Screwdriver
  • Spudger
    Spudger
  1. Lenovo Thinkpad E540 Display Screen Replacement, Battery: Schritt 1, Bild 1 von 2 Lenovo Thinkpad E540 Display Screen Replacement, Battery: Schritt 1, Bild 2 von 2
    • Push the battery release switches away from each other.
  2. Lenovo Thinkpad E540 Display Screen Replacement: Schritt 2, Bild 1 von 1
    • Remove the battery.
  3. Lenovo Thinkpad E540 Display Screen Replacement, Display Screen: Schritt 3, Bild 1 von 1
    • Remove the two stickers at the bottom corners for the screen to reveal the screws.
    • Remove the two 1mm Phillips #00 screws from underneath the stickers.
  4. Lenovo Thinkpad E540 Display Screen Replacement: Schritt 4, Bild 1 von 1
    • Slide your finger underneath the plastic and pry gently to release the clips around the display bezel.
  5. Lenovo Thinkpad E540 Display Screen Replacement: Schritt 5, Bild 1 von 1
    • Remove the six 1.3mm Phillips #00 screws from around the display.
  6. Lenovo Thinkpad E540 Display Screen Replacement: Schritt 6, Bild 1 von 1
    • Remove the plastic covering and six 1.3mm Phillips #00 screws from both sides of the display.
  7. Lenovo Thinkpad E540 Display Screen Replacement: Schritt 7, Bild 1 von 3 Lenovo Thinkpad E540 Display Screen Replacement: Schritt 7, Bild 2 von 3 Lenovo Thinkpad E540 Display Screen Replacement: Schritt 7, Bild 3 von 3
    • Remove the orange tape covering the display connector.
    • Disconnect the display's ribbon cable by lifting up the latch and flipping it over 180 degrees.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Timothy Sumner
1.052 Reputation
8 Anleitungen geschrieben
USF Tampa, Team S2-G5, Nance Spring 2018 Mitglied von USF Tampa, Team S2-G5, Nance Spring 2018
USFT-NANCE-S18S2G5
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 19
Letzte 30 Tage: 40
Insgesamt: 5,056
