Zum Hauptinhalt wechseln
Lenovo Thinkpad E540 Keyboard Replacement
Timothy Sumner
Timothy Sumner und 4 weitere Mitwirkende
Zuletzt aktualisiert am June 21, 2018
5 - 15 Minuten
Mittel
A guide on how to replace the individual keys on a Lenovo ThinkPad E540 laptop.
Was du brauchst
Werkzeuge
  • Phillips #0 Screwdriver
  • Spudger
    Spudger
  1. Lenovo Thinkpad E540 Keyboard Replacement, Battery: Schritt 1, Bild 1 von 2 Lenovo Thinkpad E540 Keyboard Replacement, Battery: Schritt 1, Bild 2 von 2
    • Push the battery release switches away from each other.
  2. Lenovo Thinkpad E540 Keyboard Replacement: Schritt 2, Bild 1 von 1
    • Remove the battery.
  3. Lenovo Thinkpad E540 Keyboard Replacement, Keyboard: Schritt 3, Bild 1 von 1
    • Push the keyboard forward towards the display to create a gap above the trackpad.
  4. Lenovo Thinkpad E540 Keyboard Replacement: Schritt 4, Bild 1 von 1
    • Remove the four 1mm Phillips #00 screws found hidden underneath the keys.
  5. Lenovo Thinkpad E540 Keyboard Replacement: Schritt 5, Bild 1 von 1
    • Tilt the keyboard forward from the top and lift gently.
    • Dont pull too far because there is a cable attached to the back.
  6. Lenovo Thinkpad E540 Keyboard Replacement: Schritt 6, Bild 1 von 2 Lenovo Thinkpad E540 Keyboard Replacement: Schritt 6, Bild 2 von 2
    • Use a spudger to lift the black latch on the ZIF connectors.
    • Remove the blue and purple ribbon cables from the ZIF connectors.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Timothy Sumner
1.052 Reputation
8 Anleitungen geschrieben
USF Tampa, Team S2-G5, Nance Spring 2018 Mitglied von USF Tampa, Team S2-G5, Nance Spring 2018
USFT-NANCE-S18S2G5
4 Mitglieder
4 Kommentare
Thank you for posting this guide. I was able to comfortably replace my keyboard on a Lenovo E540 Thinkpad after I spilled a full glass of water on it. I was able to get a replacement keyboard via AliExpress for $25.84USD -- I initially considered buying a replacement from eBay but the keyboard prices were half of the laptop's current value, which is a bit silly.
Thank you Timothy Sumner, you’re a legend! :)
Zeeshan Muhammad - Antwort
These instructions are miserably wrong for the model E540 20C6-008SUS. The keyboard is completely covered by a plastic grid that fills the large gaps between the keys. The keyboard hold-down screws are hidden by this grid. YOUR OWN PHOTO CLEARLY SHOWS THIS ! Furthermore, the keyboard can not be pushed “forward towards the display to create a gap above the trackpad “ simply because the 4 screws are holding it solidly in place. This plastic grid must be carefully pried up and out to expose the keyboard screws enough to be able to get a screwdriver in position over the screw heads.
Hewey Dewey - Antwort
With my edge 540 (submodel unknown) I was able to reach the screws by pushing the screw driver under the plastic grid. It did however slightly scuff up my F key
Dick van Zalinge -
You forgot the latch underneath the main battery.
Moose Technologies - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 26
Letzte 30 Tage: 67
Insgesamt: 10,685
