Einleitung
Are you experiencing difficulty connecting to the internet? Try replacing your WiFi card. This guide can help.
Was du brauchst
Remove the single 1mm Phillips #0 screw holding the small plastic panel in place.
Disconnect the two antenna cables from the wifi card.
Remove the single 1mm Phillips #0 screw from the wifi card.
3 weitere Personen haben diese Anleitung absolviert.
2 Kommentare zur Anleitung
Pictures show battery is still connected to laptop.
