Zum Hauptinhalt wechseln
Lenovo Thinkpad X201 Tablet Keyboard Replacement
Thomas Donahue
Thomas Donahue und 5 weitere Mitwirkende
Zuletzt aktualisiert am February 25, 2019
10 - 15 Minuten
Mittel
This guide will take you through how to replace the keyboard in your Lenovo ThinkPad X201 Tablet if it is broken or damaged.
Was du brauchst
Werkzeuge
  1. Lenovo Thinkpad X201 Tablet Keyboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • First you push the lock button on the back of the computer from lock to unlock.
  2. Lenovo Thinkpad X201 Tablet Keyboard Replacement: Schritt 2, Bild 1 von 1
    • Then you hold it on unlocked and slide the battery pack out.
  3. Lenovo Thinkpad X201 Tablet Keyboard Replacement, Keyboard: Schritt 3, Bild 1 von 3 Lenovo Thinkpad X201 Tablet Keyboard Replacement, Keyboard: Schritt 3, Bild 2 von 3 Lenovo Thinkpad X201 Tablet Keyboard Replacement, Keyboard: Schritt 3, Bild 3 von 3
    • Using a Phillips #00 screwdriver unscrew the four screws in the back of the laptop that have a keyboard symbol next to them.
  4. Lenovo Thinkpad X201 Tablet Keyboard Replacement: Schritt 4, Bild 1 von 1
    • Using your fingers push keyboard forward so it is closer to the screen than it was before
  5. Lenovo Thinkpad X201 Tablet Keyboard Replacement: Schritt 5, Bild 1 von 1
    • Use a flathead screwdriver to gently lift up on the keyboard until it comes off. Make sure you disconnect the ribbon cable from the motherboard before removing the KB completely.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Thomas Donahue
474 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team S5-G7, Peak Spring 2018 Mitglied von UMass Dartmouth, Team S5-G7, Peak Spring 2018
UMASSD-PEAK-S18S5G7
3 Mitglieder
12 Anleitungen geschrieben
Ein Kommentar
Excellent.. thank you.. I just put on my new keyboard. I appreciated seeing your photos just to make sure I didn’t miss anything.
Andy - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 17
Insgesamt: 2,530
