Zum Hauptinhalt wechseln
Lenovo V15-ADA Battery Replacement
Jacob Schorr
Jacob Schorr und 5 weitere Mitwirkende
Zuletzt aktualisiert am January 20, 2025
15 - 25 Minuten
Mittel
Unklarer Text
If your device isn’t charging or loses charge quickly, it may be time to replace the battery. Follow the instructions below to replace the battery in the Lenovo V15-ADA.
Before you begin this repair, make sure your laptop is powered off and unplugged from the charger.
Was du brauchst
Werkzeuge
Mehr anzeigen …
  1. Lenovo V15-ADA Battery Replacement, Back Panel Assembly: Schritt 1, Bild 1 von 2 Lenovo V15-ADA Battery Replacement, Back Panel Assembly: Schritt 1, Bild 2 von 2
    • Remove the 10 marked screws using a Phillips #1 screwdriver from the back plate.
    • M2.5 × 7 mm, Phillips-head (6) (RED circles)
    • M2.5 × 4 mm, Phillips-head (4) (ORANGE circles)
  2. Lenovo V15-ADA Battery Replacement: Schritt 2, Bild 1 von 2 Lenovo V15-ADA Battery Replacement: Schritt 2, Bild 2 von 2
    • After all 10 screws have been removed, insert a spudger between the bottom plate and the housing and slide across.
    • Repeat for all 4 sides until loose.
    • Pop off the back plate and set aside.
  3. Lenovo V15-ADA Battery Replacement, Battery: Schritt 3, Bild 1 von 3 Lenovo V15-ADA Battery Replacement, Battery: Schritt 3, Bild 2 von 3 Lenovo V15-ADA Battery Replacement, Battery: Schritt 3, Bild 3 von 3
    • To start the removal of the battery, disconnect the ribbon cable connecting the battery to the computer.
  4. Lenovo V15-ADA Battery Replacement: Schritt 4, Bild 1 von 3 Lenovo V15-ADA Battery Replacement: Schritt 4, Bild 2 von 3 Lenovo V15-ADA Battery Replacement: Schritt 4, Bild 3 von 3
    • The battery is held in place by 3 screws. Use the Phillips #0 screwdriver to remove the screws that secure the battery.
    • M2 × 6 mm, Phillips-head, nylok-coated (3)
  5. Lenovo V15-ADA Battery Replacement: Schritt 5, Bild 1 von 1
    • Remove the battery from the device after completing steps 1 and 2.
Abschluss
Jacob Schorr
442 Reputation
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 9
Letzte 30 Tage: 33
Insgesamt: 238
