Zum Hauptinhalt wechseln
Lenovo Yoga Tablet 10 Back Camera Replacement
Juan Benjamin
Juan Benjamin und 5 weitere Mitwirkende
Zuletzt aktualisiert am May 7, 2024
15 Minuten
Mittel
Before you proceed with this guide, you should know how to remove the back cover.
Was du brauchst
Werkzeuge
Mehr anzeigen …
  1. Lenovo Yoga Tablet 10 Back Camera Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Remove the two Phillips #000 screws.
    • These screws are located behind the stand for the device.
    • Our device did not include these screws.
  2. Lenovo Yoga Tablet 10 Back Camera Replacement: Schritt 2, Bild 1 von 1
    • Use a plastic iFixit opening tool to pry the edges of the back case loose by placing it in between the edge of the cover and the screen.
    • Do not immediately attempt to remove the back of the case without attempting Step three, or you risk snapping the back cover.
  3. Lenovo Yoga Tablet 10 Back Camera Replacement: Schritt 3, Bild 1 von 2 Lenovo Yoga Tablet 10 Back Camera Replacement: Schritt 3, Bild 2 von 2
    • Use the spudger to reach into the center of the device and pry off the back case by giving it a light force upwards.
  4. Lenovo Yoga Tablet 10 Back Camera Replacement, Back Camera: Schritt 4, Bild 1 von 2 Lenovo Yoga Tablet 10 Back Camera Replacement, Back Camera: Schritt 4, Bild 2 von 2
    • Remove one 5mm screw using the Phillips #00 Screwdriver.
  5. Lenovo Yoga Tablet 10 Back Camera Replacement: Schritt 5, Bild 1 von 3 Lenovo Yoga Tablet 10 Back Camera Replacement: Schritt 5, Bild 2 von 3 Lenovo Yoga Tablet 10 Back Camera Replacement: Schritt 5, Bild 3 von 3
    • Use the spudger to disconnect the camera and battery from the printed circuit board by putting the spudger in between the connections and the printed circuit board and pushing the spudger up.
  6. Lenovo Yoga Tablet 10 Back Camera Replacement: Schritt 6, Bild 1 von 1
    • Remove one 5mm screw with the Phillips #00 screwdriver.
  7. Lenovo Yoga Tablet 10 Back Camera Replacement: Schritt 7, Bild 1 von 3 Lenovo Yoga Tablet 10 Back Camera Replacement: Schritt 7, Bild 2 von 3 Lenovo Yoga Tablet 10 Back Camera Replacement: Schritt 7, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • Use the nylon tip tweezers to push the camera out from between the power button and the kickstand.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Juan Benjamin
490 Reputation
4 Anleitungen geschrieben
Cal Poly, Team S2-G6, White Winter 2019 Mitglied von Cal Poly, Team S2-G6, White Winter 2019
CPSU-WHITE-W19S2G6
4 Mitglieder
7 Anleitungen geschrieben
Ein Kommentar
“To reassemble your device, follow these instructions in reverse order. “ Including unripping the power switch tail, which is soldered to the board. Look at the last picture!
The camera/speaker assembly cannot be removed without unsoldering this tail.
Fixin Ma Stuff - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 11
Insgesamt: 520
