Zum Hauptinhalt wechseln
Lenovo Yoga Tablet 10 Battery Replacement
Luis Lopez
Luis Lopez und 5 weitere Mitwirkende
Zuletzt aktualisiert am May 7, 2024
15 Minuten
Schwierig
If you need to replace your faulty battery use this guide. The battery is located inside the kickstand, thus you will need to know how to remove the back facing camera and the headphone jack.
Was du brauchst
Werkzeuge
Mehr anzeigen …
  1. Lenovo Yoga Tablet 10 Battery Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Remove the two Phillips #000 screws.
    • These screws are located behind the stand for the device.
    • Our device did not include these screws.
  2. Lenovo Yoga Tablet 10 Battery Replacement: Schritt 2, Bild 1 von 1
    • Use a plastic iFixit opening tool to pry the edges of the back case loose by placing it in between the edge of the cover and the screen.
    • Do not immediately attempt to remove the back of the case without attempting Step three, or you risk snapping the back cover.
  3. Lenovo Yoga Tablet 10 Battery Replacement: Schritt 3, Bild 1 von 2 Lenovo Yoga Tablet 10 Battery Replacement: Schritt 3, Bild 2 von 2
    • Use the spudger to reach into the center of the device and pry off the back case by giving it a light force upwards.
  4. Lenovo Yoga Tablet 10 Battery Replacement, Back Camera: Schritt 4, Bild 1 von 2 Lenovo Yoga Tablet 10 Battery Replacement, Back Camera: Schritt 4, Bild 2 von 2
    • Remove one 5mm screw using the Phillips #00 Screwdriver.
  5. Lenovo Yoga Tablet 10 Battery Replacement: Schritt 5, Bild 1 von 3 Lenovo Yoga Tablet 10 Battery Replacement: Schritt 5, Bild 2 von 3 Lenovo Yoga Tablet 10 Battery Replacement: Schritt 5, Bild 3 von 3
    • Use the spudger to disconnect the camera and battery from the printed circuit board by putting the spudger in between the connections and the printed circuit board and pushing the spudger up.
  6. Lenovo Yoga Tablet 10 Battery Replacement: Schritt 6, Bild 1 von 1
    • Remove one 5mm screw with the Phillips #00 screwdriver.
  7. Lenovo Yoga Tablet 10 Battery Replacement: Schritt 7, Bild 1 von 3 Lenovo Yoga Tablet 10 Battery Replacement: Schritt 7, Bild 2 von 3 Lenovo Yoga Tablet 10 Battery Replacement: Schritt 7, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • Use the nylon tip tweezers to push the camera out from between the power button and the kickstand.
  8. Lenovo Yoga Tablet 10 Battery Replacement, Headphone Jack: Schritt 8, Bild 1 von 2 Lenovo Yoga Tablet 10 Battery Replacement, Headphone Jack: Schritt 8, Bild 2 von 2
    • Remove the headphone jack cover with tweezers by grabbing it and pulling directly up and away from the device.
  9. Lenovo Yoga Tablet 10 Battery Replacement: Schritt 9, Bild 1 von 3 Lenovo Yoga Tablet 10 Battery Replacement: Schritt 9, Bild 2 von 3 Lenovo Yoga Tablet 10 Battery Replacement: Schritt 9, Bild 3 von 3
    • Remove the two 3.5mm screws using the Phillips #00 Screwdriver.
  10. Lenovo Yoga Tablet 10 Battery Replacement: Schritt 10, Bild 1 von 3 Lenovo Yoga Tablet 10 Battery Replacement: Schritt 10, Bild 2 von 3 Lenovo Yoga Tablet 10 Battery Replacement: Schritt 10, Bild 3 von 3
    • Disconnect the headphone jack from the motherboard by placing the spudger in between the connections and motherboard and pushing up towards you.
    • Pull the wire towards the headphone jack to disconnect it.
  11. Lenovo Yoga Tablet 10 Battery Replacement: Schritt 11, Bild 1 von 2 Lenovo Yoga Tablet 10 Battery Replacement: Schritt 11, Bild 2 von 2
    • Use tweezers to remove the headphone jack by pulling it up and towards you.
  12. Lenovo Yoga Tablet 10 Battery Replacement, Battery: Schritt 12, Bild 1 von 2 Lenovo Yoga Tablet 10 Battery Replacement, Battery: Schritt 12, Bild 2 von 2
    • Use the metal spudger to push out the lock of the battery compartment by putting the metal spudger between the kickstand and the plastic and applying a force upwards.
    • Be careful as applying to much force with the metal spudger could break the plastic covering. If you feel like the plastic is going to break, change the angle at which you use the metal spudger.
    • You can only use the metal spudger on the same side as the headphone jack. Using the metal spudger on the other side will give you no results.
  13. Lenovo Yoga Tablet 10 Battery Replacement: Schritt 13, Bild 1 von 2 Lenovo Yoga Tablet 10 Battery Replacement: Schritt 13, Bild 2 von 2
    • Pull the battery compartment away from the device.
    • The battery compartment is the kickstand.
  14. Lenovo Yoga Tablet 10 Battery Replacement: Schritt 14, Bild 1 von 2 Lenovo Yoga Tablet 10 Battery Replacement: Schritt 14, Bild 2 von 2
    • Use tweezers to remove the gray tape and reveal a screw at each end of the compartment.
  15. Lenovo Yoga Tablet 10 Battery Replacement: Schritt 15, Bild 1 von 3 Lenovo Yoga Tablet 10 Battery Replacement: Schritt 15, Bild 2 von 3 Lenovo Yoga Tablet 10 Battery Replacement: Schritt 15, Bild 3 von 3
    • Remove one 3.5 mm screw from each end using the Phillips #00 screwdriver.
  16. Lenovo Yoga Tablet 10 Battery Replacement: Schritt 16, Bild 1 von 2 Lenovo Yoga Tablet 10 Battery Replacement: Schritt 16, Bild 2 von 2
    • Use tweezers to remove the cap from the side with the orange connector coming out of it.
    • You should hear a loud snap when you insert the tweezers in the middle of the cap and pull up.
  17. Lenovo Yoga Tablet 10 Battery Replacement: Schritt 17, Bild 1 von 3 Lenovo Yoga Tablet 10 Battery Replacement: Schritt 17, Bild 2 von 3 Lenovo Yoga Tablet 10 Battery Replacement: Schritt 17, Bild 3 von 3
    • Use your hands to push the battery out towards the other side of the compartment.
    • Do not lose the cap from the other side of the compartment.
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
Luis Lopez
329 Reputation
1 Anleitung geschrieben
Cal Poly, Team S2-G6, White Winter 2019 Mitglied von Cal Poly, Team S2-G6, White Winter 2019
CPSU-WHITE-W19S2G6
4 Mitglieder
7 Anleitungen geschrieben
Ein Kommentar
the battery removal is shown to be difficult
here shows the right way
https://www.youtube.com/watch?v=w0hjaxkQ...
accesscafe4015 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 9
Letzte 30 Tage: 48
Insgesamt: 5,166
