Zum Hauptinhalt wechseln
MacBook Pro 13" 2022 (M2) Heatsink Replacement
Was du brauchst
  1. MacBook Pro 13" 2022 (M2) Heatsink Replacement, Prepare your MacBook for disassembly: Schritt 1, Bild 1 von 3 MacBook Pro 13" 2022 (M2) Heatsink Replacement, Prepare your MacBook for disassembly: Schritt 1, Bild 2 von 3 MacBook Pro 13" 2022 (M2) Heatsink Replacement, Prepare your MacBook for disassembly: Schritt 1, Bild 3 von 3
    • Allow your MacBook's battery to drain below 10% before starting this repair. A charged battery may catch fire if damaged during the repair.
    • Unplug all cables and fully shut down your MacBook.
    • Close the lid and flip your MacBook over. Keep the lid closed until you've physically disconnected the battery.
    • Opening the lid will power on your MacBook. If you're using macOS Big Sur v11.1 or earlier, disable this function using this guide.
    Frag FixBot
    Kommentar hinzufügen
  2. MacBook Pro 13" 2022 (M2) Heatsink Replacement, Unfasten the lower case: Schritt 2, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    FixMat
    $36.95
    • Use a P5 Pentalobe driver to remove the six screws securing the lower case:
    • Two 6.8 mm screws
    • Two 5.3 mm screws
    • Two 3.4 mm screws
    Frag FixBot
  3. MacBook Pro 13" 2022 (M2) Heatsink Replacement, Separate the lower case: Schritt 3, Bild 1 von 2 MacBook Pro 13" 2022 (M2) Heatsink Replacement, Separate the lower case: Schritt 3, Bild 2 von 2
    • Apply a suction handle near the front edge of the lower case, between the screw holes.
    • Pull up on the suction handle to create a gap between the lower case and the frame.
    Frag FixBot
  4. MacBook Pro 13" 2022 (M2) Heatsink Replacement, Release the left clips: Schritt 4, Bild 1 von 3 MacBook Pro 13" 2022 (M2) Heatsink Replacement, Release the left clips: Schritt 4, Bild 2 von 3 MacBook Pro 13" 2022 (M2) Heatsink Replacement, Release the left clips: Schritt 4, Bild 3 von 3
    • Insert an opening pick between the lower case and the frame.
    • Slide the pick around the left corner to release the first set of clips.
    • You'll hear and feel a pop when each clip releases.
    Frag FixBot
  5. MacBook Pro 13" 2022 (M2) Heatsink Replacement, Release the right clips: Schritt 5, Bild 1 von 3 MacBook Pro 13" 2022 (M2) Heatsink Replacement, Release the right clips: Schritt 5, Bild 2 von 3 MacBook Pro 13" 2022 (M2) Heatsink Replacement, Release the right clips: Schritt 5, Bild 3 von 3
    • Slide your opening pick around the right corner to release the second set of clips securing the lower case.
    Frag FixBot
  6. MacBook Pro 13" 2022 (M2) Heatsink Replacement, Pry the lower case up: Schritt 6, Bild 1 von 3 MacBook Pro 13" 2022 (M2) Heatsink Replacement, Pry the lower case up: Schritt 6, Bild 2 von 3 MacBook Pro 13" 2022 (M2) Heatsink Replacement, Pry the lower case up: Schritt 6, Bild 3 von 3
    • Insert your opening pick between the lower case and the frame near the middle left screw hole.
    • Firmly twist the pick until the clip releases.
    • Repeat this procedure for the clip near the middle right screw hole.
    Frag FixBot
  7. MacBook Pro 13" 2022 (M2) Heatsink Replacement, Release the remaining clips: Schritt 7, Bild 1 von 3 MacBook Pro 13" 2022 (M2) Heatsink Replacement, Release the remaining clips: Schritt 7, Bild 2 von 3 MacBook Pro 13" 2022 (M2) Heatsink Replacement, Release the remaining clips: Schritt 7, Bild 3 von 3
    • Firmly pull the lower case away from the screen hinges to release the last clips securing it to the frame.
    • This motion requires significant force. Don't pull the lower case up, as you may bend the clips.
    • If it feels stuck, pull one corner at a time.
    Frag FixBot
  8. MacBook Pro 13" 2022 (M2) Heatsink Replacement, Remove the lower case: Schritt 8, Bild 1 von 2 MacBook Pro 13" 2022 (M2) Heatsink Replacement, Remove the lower case: Schritt 8, Bild 2 von 2
    • Remove the lower case.
    • To reinstall the lower case:
    • Set it in place and align the sliding clips near the display hinges. Press down and slide the lower case toward the hinges.
    • Once the lower case is secured near the hinges, press down firmly to engage the remaining four clips.
    • You'll hear and feel a pop when each clip engages.
    Frag FixBot
  9. MacBook Pro 13" 2022 (M2) Heatsink Replacement, Remove the battery board cover: Schritt 9, Bild 1 von 2 MacBook Pro 13" 2022 (M2) Heatsink Replacement, Remove the battery board cover: Schritt 9, Bild 2 von 2
    • Use blunt nose tweezers or your fingers to peel and remove the cover from the battery board, just above the middle battery cell.
    Frag FixBot
  10. MacBook Pro 13" 2022 (M2) Heatsink Replacement, Disconnect the battery data cable: Schritt 10, Bild 1 von 2 MacBook Pro 13" 2022 (M2) Heatsink Replacement, Disconnect the battery data cable: Schritt 10, Bild 2 von 2
    • Use blunt nose tweezers to gently peel back the pull tab covering the battery data connector.
    • Don't remove or tear the pull tab, as it's attached to the head of the connector.
    Frag FixBot
  11. MacBook Pro 13" 2022 (M2) Heatsink Replacement: Schritt 11, Bild 1 von 2 MacBook Pro 13" 2022 (M2) Heatsink Replacement: Schritt 11, Bild 2 von 2
    • Use the point of a spudger to flip up the small locking tab securing the battery data connector.
    • Locking tabs on ZIF connectors are fragile—be gentle with your spudger.
    Frag FixBot
  12. MacBook Pro 13" 2022 (M2) Heatsink Replacement: Schritt 12, Bild 1 von 3 MacBook Pro 13" 2022 (M2) Heatsink Replacement: Schritt 12, Bild 2 von 3 MacBook Pro 13" 2022 (M2) Heatsink Replacement: Schritt 12, Bild 3 von 3
    • Use blunt nose tweezers or your fingers to grab the battery data cable pull tab and slide it straight out of its socket.
    • Move the cable to the left, out of the way of the battery board.
    • Don't strain the cable, as it's still attached to the battery board.
    Frag FixBot
  13. MacBook Pro 13" 2022 (M2) Heatsink Replacement, Unfasten the battery connector: Schritt 13, Bild 1 von 1
    • Use a T5 Torx driver to remove the 3.7 mm screw securing the battery connector.
    Frag FixBot
  14. MacBook Pro 13" 2022 (M2) Heatsink Replacement, Disconnect the battery: Schritt 14, Bild 1 von 3 MacBook Pro 13" 2022 (M2) Heatsink Replacement, Disconnect the battery: Schritt 14, Bild 2 von 3 MacBook Pro 13" 2022 (M2) Heatsink Replacement, Disconnect the battery: Schritt 14, Bild 3 von 3
    • Use the flat end of your spudger to slightly lift the battery connector away from the battery board.
    • Lifting the connector too high will break it. Angle it enough so it won't accidentally contact the battery board during repair.
    • Optionally, you may insert a barrier, such as a piece of a playing card, between the connector and the board during the repair.
    Frag FixBot
  15. MacBook Pro 13" 2022 (M2) Heatsink Replacement, Remove the display cable bracket: Schritt 15, Bild 1 von 2 MacBook Pro 13" 2022 (M2) Heatsink Replacement, Remove the display cable bracket: Schritt 15, Bild 2 von 2
    • Use a T3 Torx driver to remove the two 3.1 mm screws securing the display cable retaining bracket.
    • Remove the bracket.
    Frag FixBot
  16. MacBook Pro 13" 2022 (M2) Heatsink Replacement, Remove the display cable cover: Schritt 16, Bild 1 von 2 MacBook Pro 13" 2022 (M2) Heatsink Replacement, Remove the display cable cover: Schritt 16, Bild 2 von 2
    • Use your T3 Torx driver to remove the two 1.7 mm screws securing the display cable cover.
    • Remove the cover.
    Frag FixBot
  17. MacBook Pro 13" 2022 (M2) Heatsink Replacement, Disconnect the display: Schritt 17, Bild 1 von 2 MacBook Pro 13" 2022 (M2) Heatsink Replacement, Disconnect the display: Schritt 17, Bild 2 von 2
    • Use the flat end of your spudger to pry up and disconnect the display cable from the display board.
    Frag FixBot
  18. MacBook Pro 13" 2022 (M2) Heatsink Replacement, Remove the left cable bracket: Schritt 18, Bild 1 von 3 MacBook Pro 13" 2022 (M2) Heatsink Replacement, Remove the left cable bracket: Schritt 18, Bild 2 von 3 MacBook Pro 13" 2022 (M2) Heatsink Replacement, Remove the left cable bracket: Schritt 18, Bild 3 von 3
    • Use your T5 Torx driver to remove the two screws securing the left cable bracket to the logic board:
    • One 3.6 mm screw
    • One 2.6 mm screw
    Frag FixBot
  19. MacBook Pro 13" 2022 (M2) Heatsink Replacement, Disconnect the interconnect cable: Schritt 19, Bild 1 von 2 MacBook Pro 13" 2022 (M2) Heatsink Replacement, Disconnect the interconnect cable: Schritt 19, Bild 2 von 2
    • Use the flat end of your spudger to pry up and disconnect the left interconnect cable.
    Frag FixBot
  20. MacBook Pro 13" 2022 (M2) Heatsink Replacement, Remove the antenna cable cover: Schritt 20, Bild 1 von 2 MacBook Pro 13" 2022 (M2) Heatsink Replacement, Remove the antenna cable cover: Schritt 20, Bild 2 von 2
    • Peel and remove the plastic cover from the antenna cables.
    Frag FixBot
  21. MacBook Pro 13" 2022 (M2) Heatsink Replacement, Disconnect the antenna bar: Schritt 21, Bild 1 von 3 MacBook Pro 13" 2022 (M2) Heatsink Replacement, Disconnect the antenna bar: Schritt 21, Bild 2 von 3 MacBook Pro 13" 2022 (M2) Heatsink Replacement, Disconnect the antenna bar: Schritt 21, Bild 3 von 3
    • Use the point of your spudger to pry up and disconnect the antenna cables from the logic board.
    • Pry on the metal head of the connector. Avoid lifting the cable itself as much as possible.
    • To reconnect the cables, align the connectors directly over their sockets and press down with the flat end of a spudger until they snap into place.
    Frag FixBot
  22. MacBook Pro 13" 2022 (M2) Heatsink Replacement, Unfasten the antenna cables: Schritt 22, Bild 1 von 1
    • Use your T5 Torx driver to remove the 3.4 mm screw securing the antenna cables to the logic board.
    Frag FixBot
  23. MacBook Pro 13" 2022 (M2) Heatsink Replacement, Disconnect the logic board: Schritt 23, Bild 1 von 3 MacBook Pro 13" 2022 (M2) Heatsink Replacement, Disconnect the logic board: Schritt 23, Bild 2 von 3 MacBook Pro 13" 2022 (M2) Heatsink Replacement, Disconnect the logic board: Schritt 23, Bild 3 von 3
    • Use the point of a spudger to flip up the small locking tab securing the right speaker connector.
    • Grab the pull tab on the head of the cable and slide it straight out of its socket.
    Frag FixBot
  24. MacBook Pro 13" 2022 (M2) Heatsink Replacement, Remove the trackpad cable bracket: Schritt 24, Bild 1 von 2 MacBook Pro 13" 2022 (M2) Heatsink Replacement, Remove the trackpad cable bracket: Schritt 24, Bild 2 von 2
    • Use your T5 Torx driver to remove the two 1.9 mm screws securing the trackpad cable bracket.
    Frag FixBot
  25. MacBook Pro 13" 2022 (M2) Heatsink Replacement, Disconnect the trackpad: Schritt 25, Bild 1 von 2 MacBook Pro 13" 2022 (M2) Heatsink Replacement, Disconnect the trackpad: Schritt 25, Bild 2 von 2
    • Use the flat end of your spudger to pry up and disconnect the trackpad cable from the logic board.
    Frag FixBot
  26. MacBook Pro 13" 2022 (M2) Heatsink Replacement: Schritt 26, Bild 1 von 2 MacBook Pro 13" 2022 (M2) Heatsink Replacement: Schritt 26, Bild 2 von 2
    • Disconnect the seven remaining ZIF connectors from the logic board by lifting their locking tabs and pulling them straight out of their sockets.
    Frag FixBot
  27. MacBook Pro 13" 2022 (M2) Heatsink Replacement, Remove the right cable bracket: Schritt 27, Bild 1 von 3 MacBook Pro 13" 2022 (M2) Heatsink Replacement, Remove the right cable bracket: Schritt 27, Bild 2 von 3 MacBook Pro 13" 2022 (M2) Heatsink Replacement, Remove the right cable bracket: Schritt 27, Bild 3 von 3
    • Use your T3 Torx driver to remove the three 1.4 mm screws securing the cable bracket to the top right of the logic board.
    Frag FixBot
  28. MacBook Pro 13" 2022 (M2) Heatsink Replacement, Disconnect the top right press connectors: Schritt 28, Bild 1 von 3 MacBook Pro 13" 2022 (M2) Heatsink Replacement, Disconnect the top right press connectors: Schritt 28, Bild 2 von 3 MacBook Pro 13" 2022 (M2) Heatsink Replacement, Disconnect the top right press connectors: Schritt 28, Bild 3 von 3
    • Use the point of your spudger to pry up and disconnect the Touch Bar press connector from the top right of the logic board.
    • Repeat this step for the lid angle sensor and the Thunderbolt ports press connectors.
    Frag FixBot
  29. MacBook Pro 13" 2022 (M2) Heatsink Replacement, Remove the top left cable cover: Schritt 29, Bild 1 von 3 MacBook Pro 13" 2022 (M2) Heatsink Replacement, Remove the top left cable cover: Schritt 29, Bild 2 von 3 MacBook Pro 13" 2022 (M2) Heatsink Replacement, Remove the top left cable cover: Schritt 29, Bild 3 von 3
    • Use your T3 Torx driver to remove the two screws securing the cable cover near the headphone jack:
    • One 1.4 mm screw
    • One 4.9 mm screw
    • Remove the cover.
    Frag FixBot
  30. MacBook Pro 13" 2022 (M2) Heatsink Replacement, Unfasten the logic board: Schritt 30, Bild 1 von 2 MacBook Pro 13" 2022 (M2) Heatsink Replacement, Unfasten the logic board: Schritt 30, Bild 2 von 2
    • Remove the five screws securing the logic board:
    • One 3.0 mm hex head screw
    • One 3.7 mm T5 Torx screw
    • Three 3.3 mm T5 Torx screws
    Frag FixBot
  31. MacBook Pro 13" 2022 (M2) Heatsink Replacement, Reassembly information: Schritt 31, Bild 1 von 3 MacBook Pro 13" 2022 (M2) Heatsink Replacement, Reassembly information: Schritt 31, Bild 2 von 3 MacBook Pro 13" 2022 (M2) Heatsink Replacement, Reassembly information: Schritt 31, Bild 3 von 3
    • Your 3.0 mm nut driver may be too long to thread the hex head screw in. Use one of the following techniques to begin threading the screw in:
    • Thread the screw in using your fingertips.
    • Thread the screw in using blunt nose tweezers.
    • Use your T3 Torx driver to install the 1.4 mm screw into the hex head screw. Then, install the hex head screw using the T3 Torx driver. Finally, hold the hex head screw while you remove the 1.4 mm screw.
    • Once the hex head screw is threaded in a few turns, tighten it using your nut driver.
    Frag FixBot
  32. MacBook Pro 13" 2022 (M2) Heatsink Replacement, Pry up the logic board: Schritt 32, Bild 1 von 2 MacBook Pro 13" 2022 (M2) Heatsink Replacement, Pry up the logic board: Schritt 32, Bild 2 von 2
    • Insert the point of your spudger between the bottom left of the logic board and the left speaker assembly.
    • Pry up on the logic board until you can grab it with your fingers.
    Frag FixBot
  33. MacBook Pro 13" 2022 (M2) Heatsink Replacement, Remove the logic board: Schritt 33, Bild 1 von 3 MacBook Pro 13" 2022 (M2) Heatsink Replacement, Remove the logic board: Schritt 33, Bild 2 von 3 MacBook Pro 13" 2022 (M2) Heatsink Replacement, Remove the logic board: Schritt 33, Bild 3 von 3
    • Grip the bottom left edge of the logic board.
    • Pull the logic board down and left to free it from the press connectors and antenna cables in the upper right corner.
    • Lift the logic board out of its recess, making sure not to catch on any loose cables.
    • During reassembly, make sure all 15 connectors are above the logic board before reinstalling it.
    Frag FixBot
  34. MacBook Pro 13" 2022 (M2) Heatsink Replacement, Remove the rubber spacer: Schritt 34, Bild 1 von 3 MacBook Pro 13" 2022 (M2) Heatsink Replacement, Remove the rubber spacer: Schritt 34, Bild 2 von 3 MacBook Pro 13" 2022 (M2) Heatsink Replacement, Remove the rubber spacer: Schritt 34, Bild 3 von 3
    Frag FixBot
  35. MacBook Pro 13" 2022 (M2) Heatsink Replacement, Prepare your work area: Schritt 35, Bild 1 von 1
    Microfiber Cleaning Cloths
    $3.99
    • Flip the logic board over and lay it down on a soft surface, such as a microfiber cloth.
    Frag FixBot
  36. MacBook Pro 13" 2022 (M2) Heatsink Replacement, Unfasten the heatsink: Schritt 36, Bild 1 von 2 MacBook Pro 13" 2022 (M2) Heatsink Replacement, Unfasten the heatsink: Schritt 36, Bild 2 von 2
    • Use a Torx T5 driver to unfasten the four 3.8 mm screws securing the tension brackets.
    • As you remove each screw, hold down the tension bracket with a finger to prevent the screw from ejecting.
    • During reassembly, install each screw only a few turns to ensure the heatsink aligns properly. Once all four screws are threaded in, finish tightening them.
    Frag FixBot
  37. MacBook Pro 13" 2022 (M2) Heatsink Replacement, Remove the tension brackets: Schritt 37, Bild 1 von 1
    • Remove the tension brackets.
    Frag FixBot
  38. MacBook Pro 13" 2022 (M2) Heatsink Replacement, Remove the logic board: Schritt 38, Bild 1 von 3 MacBook Pro 13" 2022 (M2) Heatsink Replacement, Remove the logic board: Schritt 38, Bild 2 von 3 MacBook Pro 13" 2022 (M2) Heatsink Replacement, Remove the logic board: Schritt 38, Bild 3 von 3
    • Lift the logic board straight off the heatsink.
    • Before reassembling, follow this guide to apply new thermal paste to the heatsink and CPU.
    Frag FixBot
Abschluss
Repair didn’t go as planned? Try some basic troubleshooting or search our Answers community for help.
Guide Team Mitglied von Guide Team
Staff
10 Mitglieder
19.310 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 25
Letzte 30 Tage: 150
Insgesamt: 4,570
