Einleitung
Use this guide to replace the antenna cable assembly of your MacBook Pro 13" Touch Bar Late 2016.
  1. Before starting this procedure, you must disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide or follow the abbreviated instructions below to disable Auto Boot.
    • Before starting this procedure, you must disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide or follow the abbreviated instructions below to disable Auto Boot.
    • Power on your Mac and launch Terminal.
    • Copy and paste the following command (or type it exactly) into Terminal:
      • sudo nvram AutoBoot=%00
    • Press [return]. If prompted, enter your administrator password and press [return] again. Note: Your return key may also be labeled ⏎ or "enter."
    • You can now safely power down your Mac and open the bottom case, without it accidentally powering on.
    • When your repair is complete and your Mac is successfully reassembled, re-enable Auto Boot with the following command:
      • sudo nvram AutoBoot=%03
    Kommentar hinzufügen
    • Before proceeding, unplug and power down your MacBook. Close the display and lay it on a soft surface, top-side down.
    • Use a P5 Pentalobe driver to remove the six screws securing the lower case:
      • Two 6.2 mm screws
      • Four 3.4 mm screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
    • Apply a suction handle to the lower case near the front-center area of the MacBook Pro.
    • Lift the suction handle to create a slight separation between the lower case and the chassis.
    • Insert one corner of an opening pick into the space between the lower case and the chassis.
    • Slide the opening pick around the nearest corner and halfway up the side of the case.
      • This releases the first of the hidden clips securing the lower case to the chassis. You should feel and hear the clip pop free.
    • Repeat the previous step on the opposite side, sliding your opening pick under the lower case and up the side to pop the second clip free.
    • Insert your opening pick once again under the front edge of the lower case, near one of the two centermost screw holes.
    • Give the pick a firm twist to pop free the third clip securing the lower case to the chassis.
    • Repeat this procedure near the other of the two centermost screw holes, popping the fourth clip free.
    • Pull the lower case firmly towards the front of the MacBook (away from the hinge area) to separate the last of the clips securing the lower case.
      • It may help to pull first at one corner, then the other. In case you aren't able to separate the clip from the lower case you can apply a suction cup next to the corner with the clip and carefully use it as a pulling handle.
    • Remove the lower case.
    • Carefully peel up the large piece of tape covering the battery connector, on the edge of the logic board nearest the battery.
    • Remove the tape.
    • Gently peel back the small piece of tape covering the battery board data cable connector.
      • The tape is integrated into the ribbon cable and will not detach completely. Simply peel it back enough to access the connector.
    • Use the tip of a spudger to flip up the small black locking tab securing the cable in its connector.
    • Disconnect the battery board data cable by sliding it out from its socket.
    • Slide parallel to the logic board, in the direction of the cable.
    • Fold the battery board data cable to the side and out of the way.
    • Use a T5 Torx driver to remove the 3.7 mm pancake screw securing the battery power connector.
    • Use a spudger to gently lift the battery power connector, disconnecting the battery.
    • Lift the connector high enough so that it stays separated from its socket. If it accidentally makes contact during the course of your repair, it could damage your MacBook Pro.
    • Remove the four 1.9 mm T3 Torx screws securing the plastic covers on top of the display hinges.
    • Remove the two plastic covers in the left and right corner of the Macbook with a pair of tweezers.
    • Remove the two 2.9 mm T3 Torx screws securing the aluminum cover on top of the main display cable.
    • Remove the aluminium cover with a pair of tweezers.
    • Remove the two 1.7 mm T3 Torx screws securing the aluminum cover on top of the display cable flex connector.
    • Use the flat end of a spudger to carefully disconnect the display cable.
    • Remove the four 1.5 mm T3 Torx screws securing the two aluminum covers on top of the two display cable connectors.
    • Use a pair of tweezers to remove the two aluminium covers.
    • Remove the four 3.9 mm T5 Torx screws on both sides, which secure the antenna cable assembly.
    • Also remove the twelve 1.1 mm P2 screws on both sides.
    • Use a pair of tweezers to disconnect the three coax cables from the main board.
    • Remove the 2.8 mm T5 Torx screw securing the three coax cables to the main board.
    • Use an opening pick to lever out the antenna cable assembly in three separate actions.
      • Do not slide the opening pick from one side to the other because there are two display cables that can be damaged.
    • Insert the opening pick beneath the right side of the antenna cable assembly and lever it out. Pull it out and repeat the procedure in the middle between the two display cables. Repeat once more on the left side of the assembly.
    • Carefully start removing the antenna cable assembly by pulling it slightly upwards and away from the MacBook.
      • You'll be pulling the three coax cables beneath the heat pipe. Be careful not to damage them nor the heat pipe.
    • Remove the antenna cable assembly.
Abschluss
Dominik Schnabelrauch
Mitglied seit 23.11.2016
21.488 Reputation
109 Anleitungen geschrieben
iFixit Mitglied von iFixit
Community
114 Mitglieder
7.277 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 3
Letzte 7 Tage: 28
Letzte 30 Tage: 128
Insgesamt: 353
