Marshall Uxbridge LED Board Replacement
Einleitung
Zu Schritt 1 der AnleitungIf your Marshall Uxbridge speaker (model 1005605) LED lights are not working, use this guide to replace the LED board.
The LED board controls the lights on the front of the speaker. A faulty board will cause the lights to fade or completely stop working.
Before using this guide, check your speaker for debris or dust buildup. If present, remove dust and debris using the steps found here:
Before beginning, make sure to power off your speaker completely and unplug from the power source.
Was du brauchst
Werkzeuge
Mehr anzeigen …
Orient your speaker so that the back is facing you.
Use a Phillips #2 screwdriver to remove the six 19mm screws from the back plate.
Use an iFixit opening pick to remove and lift the back plate to expose the connected wires.
Detach the white connector from inside the bottom of the back panel.
Detach the small red and white connectors from the motherboard on the left side of the back panel.
Pull the blue ribbon cables from the motherboard.
Remove the back panel from the speaker base.
Orient the bottom of the speaker to face away from you.
Use a Phillips #1 screwdriver to remove the two 12 mm screws holding the power relay in place.
Separate the power relay from the speaker.
Slide out the blue ribbon cable from the power relay.
Put the power relay to the side.
Remove the two 6 mm screws connected to the LED board using a TR9 Torx screwdriver.
Pull the blue ribbon cable to lift the LED board.
Pull the blue ribbon cable out of the LED board.
