Zum Hauptinhalt wechseln
Marshall Uxbridge Power Port Replacement
Angie Delgado
Angie Delgado und 3 weitere Mitwirkende
Zuletzt aktualisiert am January 3, 2025
15 Minuten
Leicht
If your Marshall Uxbridge speaker (model 1005605) does not work even when plugged in, use this guide to replace the power port.
The power port connects the power cord to the speaker. A faulty power port can cause power failure.
Before using this guide, inspect the power cord to ensure it is plugged into the correct outlet for the device and is free from damage.
Before you begin, make sure to power off completely and disconnect from the power source.
Was du brauchst
iFixit erhält eine Provision, wenn du über diese Links etwas kaufst.
  1. Marshall Uxbridge Power Port Replacement, Back Panel: Schritt 1, Bild 1 von 3 Marshall Uxbridge Power Port Replacement, Back Panel: Schritt 1, Bild 2 von 3 Marshall Uxbridge Power Port Replacement, Back Panel: Schritt 1, Bild 3 von 3
    • Orient your speaker so that the back is facing you.
    • Use a Phillips #2 screwdriver to remove the six 19mm screws from the back plate.
    • Use an iFixit opening pick to remove and lift the back plate to expose the connected wires.
  2. Marshall Uxbridge Power Port Replacement: Schritt 2, Bild 1 von 2 Marshall Uxbridge Power Port Replacement: Schritt 2, Bild 2 von 2
    • Detach the white connector from inside the bottom of the back panel.
    • Detach the small red and white connectors from the motherboard on the left side of the back panel.
  3. Marshall Uxbridge Power Port Replacement: Schritt 3, Bild 1 von 1
    • Pull the blue ribbon cables from the motherboard.
    • Remove the back panel from the speaker base.
  4. Marshall Uxbridge Power Port Replacement, Power Port: Schritt 4, Bild 1 von 2 Marshall Uxbridge Power Port Replacement, Power Port: Schritt 4, Bild 2 von 2
    • Use a Phillips #2 screwdriver to remove the two 12 mm screws holding the power port to the back plate.
    • Remove the power port from the back plate.
  5. Marshall Uxbridge Power Port Replacement: Schritt 5, Bild 1 von 1
    • Follow the power port wire and locate the white connector.
  6. Marshall Uxbridge Power Port Replacement: Schritt 6, Bild 1 von 2 Marshall Uxbridge Power Port Replacement: Schritt 6, Bild 2 von 2
    • Unplug the power port cord from the board at the white connector by pushing down on the tab, holding onto the connector, and pulling the connector out.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Angie Delgado
390 Reputation
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 22
Insgesamt: 80
