Einleitung
This guide shows how to remove and replace a speaker assembly for the Meta Quest 2.
The speaker assembly includes the speaker and the arm, which guides the sound to the ear.
This guide is written with the left speaker, oriented as you wear the headset. If you’re replacing the right speaker (or both), you can use the same procedure.
Removing the speaker assembly requires significant disassembly of your headset. If your battery is worn, consider taking this opportunity to replace it—it's normally hard to reach but is easily accessible during this repair.
Note: You'll need a long PH00 bit or a dedicated PH00 screwdriver to remove some recessed screws.
Was du brauchst
Hold the power button for three seconds to fully turn off your headset.
Grasp and pull on the nose section of the facial interface to unclip it from the headset.
Grasp and pull on the top section of the facial interface to unclip it from the headset.
Use your fingers to grasp the right strap near the headset.
Peel the right strap away from the headset arm to unclip it.
Unthread the top strap from its bracket.
Remove the head strap.
Use a Torx T2 driver to remove the six 3.5 mm‑long screws securing the eyepiece trim.
Insert an opening pick into the seam between the eyepiece trim and white outer shell, near the nose cutout.
Slide the opening pick to the right along the seam to release the clips securing the eyepiece trim.
Pry with the opening pick to release the clips securing the right side of the eyepiece trim.
Leave the opening pick in the seam to prevent the clips from reengaging.
Repeat the prying procedure along the left edge to release the clips securing the eyepiece trim.
Lift the eyepiece trim slightly and tilt it towards the top edge of the headset.
Set the trim down on your work surface, making sure not to strain the cable.
Use the point of a spudger to flip open the black lock tab on the ZIF connector securing the face sensor cable.
Use tweezers to pull the face sensor cable out of the ZIF connector.
Make sure the lens spacing matches the spacing indicator. This allows the indicator peg to sit correctly in its notch.
If the lens spacing doesn't match the indicator, manually adjust the lens with your fingers.
Thread your fingers through the eyepiece trim’s eyeholes and grasp the edges of the sensor cable.
Slide the sensor cable into the socket until the first set of tabs rests in the socket. This should flip the lock tab down partially.
Use a spudger to press the lock tab down towards the cable to lock it in place.
Use a Phillips screwdriver to remove the five 7.7 mm‑long screws securing the front cover to the headset:
One recessed in the top-left corner
One recessed in the top-right corner
Three along the lower edge
Insert an opening pick into the seam between the bottom edge of the front cover and the headset.
Pry with the opening pick to release the front cover clips.
Slide the opening clip along the seam and pry to release all the clips securing the front cover.
Use a pair of tweezers to grasp the metal neck of the top-right antenna cable.
Lift the antenna connector straight up to disconnect it.
Guide the antenna cable out of its metal clip holding it in place.
Use a Phillips screwdriver to remove the three screws securing the battery cable bracket:
One 4.4 mm‑long screw
Two 2.3 mm‑long screws
Use tweezers or your fingers to grasp the battery cable bracket.
Twist the cable bracket slightly so that its bottom left corner unclips from the motherboard.
Remove the battery cable bracket.
Use a spudger to pry up and disconnect the battery press connector from the motherboard.
Insert one arm of a pair of tweezers under the metal neck of the black antenna cable near the fan assembly.
Use a Phillips screwdriver to remove the eight screws securing the antenna assembly to the headset:
Four 4.4 mm‑long screws
Two 4.8 mm‑long screws
Two 10.7 mm‑long screws
Use your fingers to flip up the antenna assembly enough to access the cable underneath it.
Use tweezers to grab the fan connector and carefully slide it out of its socket.
Use the point of an opening pick to loosen the adhesive securing the LED flex cable from the top of the fan assembly.
Remove the two screws securing the fan assembly to the headset:
One 4.4 mm‑long Phillips screw
One 3.6 mm‑long Torx T2 screw
Use a Phillips screwdriver to remove the four 2.3 mm‑long screws securing the heat sink to the motherboard.
Two speaker connectors
Seven ZIF connectors
Two press connectors
One antenna connector
Use tweezers to grip the left speaker cables at the base of their motherboard connector.
Lift the connector gently straight up to disconnect it.
Use tweezers to gently peel the black tape covering the two top flex cables.
Use a clean fingernail or a spudger to pry up the lock tab securing the top left camera cable.
Grasp the top left camera cable with tweezers and slide it out of its ZIF connector.
Move counter-clockwise around the motherboard and disconnect the remaining six ZIF connectors:
Power button and LED board
Bottom left camera
Bottom right camera
Top right camera
Face sensor interconnect cable
Indicator LED cable
Use a spudger to pry up and disconnect the display cable.
Insert one arm of a pair of tweezers under the metal neck of the side antenna cable.
Remove the five screws securing the motherboard to the headset:
Four 3.8 mm‑long Phillips screws
One 6 mm‑long 3.5 mm hex standoff screw
Use your fingers or tweezers to peel and remove the two camera covers from the top cameras.
Peel and remove the black tape covering the antenna cable.
Use tweezers to lift and unclip the black antenna cable from the metal grounding clips.
Use a spudger to pry up the black lock tab securing the left microphone flex cable to the left interconnect cable.
Use your fingers or tweezers to slide the microphone cable out of the ZIF connector.
Slide the point of an opening pick underneath the battery flex cable to loosen the adhesive securing it from the headset.
Use a Phillips screwdriver to remove the four screws securing the screen and lens assembly to the frame:
Two 6.5 mm‑long screws
Two 7.7 mm‑long screws
Grasp the screen and lens assembly with your fingers.
Slowly lift and separate the assembly from the outer shell, taking care to reposition any cables that get in the way.
Remove the screen and lens assembly.
Three cables along the top edge—two flex cables and one LED flex cable
Two cables in the top right corner—the battery connector and an antenna cable
Two cables along the right edge—an antenna cable and a wide flex cable
Two flex cables along the bottom edge
Three cables along the left edge—one antenna cable, one flex cable, and one speaker cable
Use tweezers or your fingers to guide the speaker cable out of its two plastic clips.
Clip this cable neatly into the guide clips to prevent it from getting pinched by the screen and lens assembly.
Use a Phillips screwdriver to remove the four 4.5 mm‑long screws securing the outer speaker bracket to the outer shell.
Use a spudger to pry the outer speaker bracket off of the gaskets securing it to the speaker assembly.
Remove the outer speaker bracket.
Insert one arm of a pair of tweezers under the lip of a metal clip.
Use tweezers to grasp the clip by the lip and pull out the clip from its recess.
Repeat the process for the three remaining clips.
Grasp the inner speaker bracket with your fingers and twist it counterclockwise to unlock it from the speaker assembly.
Thread the speaker assembly wire through the inner speaker bracket.
Remove the speaker assembly.
2 weitere Personen haben diese Anleitung absolviert.
2 Kommentare
thank so much
