Motorola C290 Logic Board Replacement
Einleitung
Zu Schritt 1 der AnleitungThis repair guide will show how to get to the logic board and replace it
Was du brauchst
Position Motorola C290 so that the back of the phone is facing up.
Apply pressure to the back cover while simultaneously sliding it downwards.
Place your finger in the notch at the top of the battery.
Gently lift and pull out battery.
Unscrew antenna head from top of phone by twisting counterclockwise.
Pull the antenna out through the top hole and set aside.
Remove the plastic tube by lifting the bottom and pulling out towards yourself.
Insert a Spudger (or pushpin) into the top notch of the rubber cover, located on the top of the phone.
Press down and rotate the Spudger lifting the rubber cover. Remove and set cover aside.
Using a T6 Torx screwdriver, unscrew all 5 screws and carefully set them aside.
Insert the plastic opening tool in the groove at the top of the phone.
Rotate the tool to create an opening between the logic board cover and case.
Slide the plastic opening tool along the groove, until the entire logic board cover has been opened.
Remove logic board cover and set aside.
Insert the Spudger into the slot on the top of the logic board.
Gently pry to loosen the top of the logic board.
Grab the top of the logic board and pull at an angle to remove.
Eine weitere Person hat diese Anleitung absolviert.
