Zum Hauptinhalt wechseln
Motorola E815 Front Screen Replacement
Zoie E
Zoie E und 4 weitere Mitwirkende
Zuletzt aktualisiert am May 7, 2024
10 Minuten
Mittel
Action Shots
If the front screen of your E815 is cracked or broken, you need to replace the screen. In most cases, a cracked screen is clearly visible by ink blots or radiating shatter patterns throughout the screen.
In this guide, you will:
  • Dissemble the E815
  • Access the front screen
  • Replace the screen
  1. Motorola E815 Front Screen Replacement, Battery: Schritt 1, Bild 1 von 1
    • Locate the back cover release slide.
    • Use your finger to slide it down.
  2. Motorola E815 Front Screen Replacement: Schritt 2, Bild 1 von 1
    • Remove the back cover by pulling it away from the phone.
  3. Motorola E815 Front Screen Replacement: Schritt 3, Bild 1 von 2 Motorola E815 Front Screen Replacement: Schritt 3, Bild 2 von 2
    • Locate the battery removal slot.
    • Use your finger to pull the battery out from the top.
    • Remove the battery.
  4. Motorola E815 Front Screen Replacement, Disassembling Motorola E815 Antenna: Schritt 4, Bild 1 von 1
    • Locate the antenna port on the top of the phone.
  5. Motorola E815 Front Screen Replacement: Schritt 5, Bild 1 von 2 Motorola E815 Front Screen Replacement: Schritt 5, Bild 2 von 2
    • Grip the plastic support post and unscrew the apparatus using a counterclockwise twist.
    • Pull the apparatus up and out of the phone.
  6. Motorola E815 Front Screen Replacement, Front Screen: Schritt 6, Bild 1 von 3 Motorola E815 Front Screen Replacement, Front Screen: Schritt 6, Bild 2 von 3 Motorola E815 Front Screen Replacement, Front Screen: Schritt 6, Bild 3 von 3
    • Locate the two screws on the backside of the phone.
    • Unscrew the two screws using your T6 screwdriver.
  7. Motorola E815 Front Screen Replacement: Schritt 7, Bild 1 von 3 Motorola E815 Front Screen Replacement: Schritt 7, Bild 2 von 3 Motorola E815 Front Screen Replacement: Schritt 7, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • Grasp the top of the phone near the speaker.
    • Gently pull the top section of the phone upwards until you feel some resistance.
    • Locate the brown connector that runs from the top section of the phone to the circuit board under the keypad.
    • Using tweezers, gently pry the connector from the circuit board.
    • Detach the top section of the phone from the keypad section.
  8. Motorola E815 Front Screen Replacement: Schritt 8, Bild 1 von 2 Motorola E815 Front Screen Replacement: Schritt 8, Bild 2 von 2
    • Carefully insert the blue pry tool into the notch between the two halves of the top section of the phone.
    • Gently pry the two halves apart.
  9. Motorola E815 Front Screen Replacement: Schritt 9, Bild 1 von 1
    • Rotate the top section of the phone around so that you are looking at the outer screen.
    • Disconnect the cover from the outer screen side of the phone.
  10. Motorola E815 Front Screen Replacement: Schritt 10, Bild 1 von 3 Motorola E815 Front Screen Replacement: Schritt 10, Bild 2 von 3 Motorola E815 Front Screen Replacement: Schritt 10, Bild 3 von 3
    • Rotate the top section of the phone around so you are looking at the large screen.
    • Using your fingers, lift the protector off of the screen.
  11. Motorola E815 Front Screen Replacement: Schritt 11, Bild 1 von 1
    • Using the blue pry tool, gently remove the screen cover.
    • Since it is glued into place, it may take some maneuvering to remove.
  12. Motorola E815 Front Screen Replacement: Schritt 12, Bild 1 von 3 Motorola E815 Front Screen Replacement: Schritt 12, Bild 2 von 3 Motorola E815 Front Screen Replacement: Schritt 12, Bild 3 von 3
    • Turn the phone so that you can see the side metal clasps.
    • Using the blue lifter tool, snap the metal clasps off of screen body.
    • Proceed to snap all four corners of the metal cover off of the screen body.
  13. Motorola E815 Front Screen Replacement: Schritt 13, Bild 1 von 2 Motorola E815 Front Screen Replacement: Schritt 13, Bild 2 von 2
    • Using tweezers, gently detach the brown connecting strip from the back of the screen.
    • Separate the screen from the phone frame.
    • The front screen can now be accessed and replaced!
Abschluss
Zoie E
603 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 14-8, Forte Winter 2011 Mitglied von Cal Poly, Team 14-8, Forte Winter 2011
CPSU-FORTE-W11S14G8
5 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 2,352
