Einleitung
Use this guide to remove or replace the back cover on your Motorola Edge 5G UW (2022).
You'll need replacement adhesive to complete this repair.
Was du brauchst
Heat an iOpener and apply it to the back cover's left edge for two minutes.
Apply a suction cup to the back of the phone, as close to the bottom left corner as possible.
Pull up on the suction cup with a strong, steady force to create a gap between the back cover and the midframe on the left edge.
Insert an opening pick into the gap.
Slide the pick along the left edge of the phone to slice the adhesive securing the back cover to the frame.
Leave the pick inserted in the top left corner to prevent the adhesive from resealing.
Apply a heated iOpener to the back cover's top edge for two minutes.
Slide the pick along the top edge to slice the adhesive.
Leave the opening pick inserted in the top right corner to prevent the adhesive from resealing.
Slide the pick along the right edge to slice the adhesive.
Leave the pick inserted in the bottom right corner to prevent the adhesive from resealing.
There's a significant amount of adhesive to the right of the cameras that secures the back cover to the motherboard cover.
Apply a heated iOpener to the right of the cameras for two minutes.
Insert an opening pick between the back cover and motherboard cover on the top right edge.
Gently pull up on the back cover while sliding the opening pick back and forth along the right side of the cameras to slice the adhesive.
Lift the back cover from the phone and remove it.
This is a good point to test your phone's functionality before sealing it up. Use this guide to run a hardware test. Be sure to power your phone back down completely before you continue working.
Follow this guide to replace the back cover adhesive.
To reassemble your device, follow the instructions in reverse order.
