Zum Hauptinhalt wechseln
Motorola Entice w766 Motherboard Replacement
Aalan Miranda
Aalan Miranda und 3 weitere Mitwirkende
Zuletzt aktualisiert am May 7, 2024
5 - 6 Minuten
Mittel
Unklarer Text
This guide's main purpose is to show how to replace the motherboard. It will not only show steps to disassemble the phone, but will also provide the knowledge needed to successfully complete each step. This guide will show the necessary tools one would need to completely disassemble this device to the motherboard and will furthermore indicate what to look for to determine if it is damaged.
Was du brauchst
Werkzeuge
Mehr anzeigen …
  1. Motorola Entice w766 Motherboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Slide the tab off the back of the device.
  2. Motorola Entice w766 Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Use the tab located at the top of the battery to release the battery.
  3. Motorola Entice w766 Motherboard Replacement, Motherboard: Schritt 3, Bild 1 von 3 Motorola Entice w766 Motherboard Replacement, Motherboard: Schritt 3, Bild 2 von 3 Motorola Entice w766 Motherboard Replacement, Motherboard: Schritt 3, Bild 3 von 3
    • The six screws need to be taken out with any conventional screw driver tool.
    • You will have to unscrew the six 5.31 mm Star Head #5 screws with the appropriate six star bit.
    • There should be six screws removed from the casing after completion.
  4. Motorola Entice w766 Motherboard Replacement: Schritt 4, Bild 1 von 3 Motorola Entice w766 Motherboard Replacement: Schritt 4, Bild 2 von 3 Motorola Entice w766 Motherboard Replacement: Schritt 4, Bild 3 von 3
    • First you will need to locate the lip on the left side of the device.
    • Next you will insert the black spudger firmly into side opening to loosen the casing.
    • Using the blue pry tool gently remove the black and silver casing.
    • The motherboard should then be exposed after removal.
  5. Motorola Entice w766 Motherboard Replacement: Schritt 5, Bild 1 von 3 Motorola Entice w766 Motherboard Replacement: Schritt 5, Bild 2 von 3 Motorola Entice w766 Motherboard Replacement: Schritt 5, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • Remove the flex cable with a pair of tweezers.
    • Be gentle with the flex cable as not to break the connecting wire.
    • Now use a spudger or pry tool to place firmly under the motherboard.
    • After creating clearance with the spudging device grab and remove the motherboard with a clamping tool or hand.
    • Look at the motherboard for scorches or loose pieces which could indicate damage.
    • Refer to the troubleshooting page for further advice to replace the motherboard.
Abschluss
Aalan Miranda
210 Reputation
2 Anleitungen geschrieben
IUPUI-Harley-F16S2G4 Mitglied von IUPUI-Harley-F16S2G4
Community
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 3
Insgesamt: 252
