Zum Hauptinhalt wechseln
Motorola Moto E4 Motherboard Cover Replacement
Nate Tjepkema
Nate Tjepkema und 3 weitere Mitwirkende
Zuletzt aktualisiert am March 8, 2022
5 Minuten
Mittel
Use this guide to remove the Moto E4 motherboard cover. Doing so allows access to the front facing camera, the rear facing camera, and the motherboard.
Was du brauchst
Werkzeuge
  • Spudger
    Spudger
  • iFixit Opening Tool
    iFixit Opening Tool
  • Phillips #00 Screwdriver
Mehr anzeigen …
  1. Motorola Moto E4 Motherboard Cover Replacement, Remove the rear cover: Schritt 1, Bild 1 von 2 Motorola Moto E4 Motherboard Cover Replacement, Remove the rear cover: Schritt 1, Bild 2 von 2
    • Before removing the battery, power off your Moto E4.
    • Remove the plastic cover by gently prying it up from the notch at the bottom right corner of the phone.
    • With the phone face down, lift the battery up by the labeled tab and remove it from the device.
  2. Motorola Moto E4 Motherboard Cover Replacement, Motherboard Cover: Schritt 2, Bild 1 von 2 Motorola Moto E4 Motherboard Cover Replacement, Motherboard Cover: Schritt 2, Bild 2 von 2
    • Remove all nine 4mm screws from the top plastic cover with a Phillips driver.
  3. Motorola Moto E4 Motherboard Cover Replacement: Schritt 3, Bild 1 von 2 Motorola Moto E4 Motherboard Cover Replacement: Schritt 3, Bild 2 von 2
    • Gently pry up the plastic cover from the gap between it and the phone edge.
    • Start on the right side as indicated by the first picture.
    • Continue prying around the rest of the cover in a counter clockwise path.
    • Once loose, remove the plastic cover from the phone.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Nate Tjepkema
1.254 Reputation
7 Anleitungen geschrieben
Cal Poly, Team S2-G4, White Winter 2019 Mitglied von Cal Poly, Team S2-G4, White Winter 2019
CPSU-WHITE-W19S2G4
4 Mitglieder
22 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 622
