Motorola Razr V3 Motherboard Replacement
Einleitung
Zu Schritt 1 der AnleitungBy following this guide you will remove the motherboard of the device. You may need to do this if your phone wont turn on and all other parts are still functional.
Was du brauchst
Werkzeuge
Mehr anzeigen …
Remove the back cover by pressing down the silver button.
Pull the cover away from the phone.
Remove the battery by pushing down on the top and pulling it away from the phone.
Remove the SIM card by pulling it toward the top of the phone with your thumb.
Pry open the back of the phone using the spudger. There are four clips, one on the left, one on the right, and two on the bottom of the phone.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Using tweezers, disconnect the copper ribbon on the left side of the phone by pulling it up from the circuit board.
Remove the antenna by pushing in the tabs on the sides with the spudger, and pulling it out.
Use a spudger or blue opening tool to pry the motherboard away from the back casing.
3 weitere Personen haben diese Anleitung absolviert.
Ein Kommentar
Step 7 seems wrong to me. I almost broke my phone following the instructions.
To remove the antenna, you remove the two black plastic/rubber stoppers by prying them out. Then you have access to the two tabs underneath the stoppers. There are also tabs on the clear housing than hook into the bottom of the tabs on the main casing used to hold the two parts of the case together. I started on one side and gently went across, prying the tabs up.
