Zum Hauptinhalt wechseln
Motorola V180 Battery Replacement
Tyler Knisley
Tyler Knisley und 13 weitere Mitwirkende
Zuletzt aktualisiert am February 18, 2025
1 - 2 Minuten
Sehr einfach
Studierende im Gange!
The Motorola v180 is a flip phone with a front screen and a main LED display. It is small and compact, and has a 820 mAh lithium ion battery that lasts 5.8 hours during full media use.
This guide will cover the steps required to safely remove the battery unit on a Motorola V180. Before using this guide, it is recommended to review the Motorola v180 manual to understand more about the battery use, installing and charging of the battery unit.
Before replacing the battery unit, make sure to power off the phone completely and disconnect it from any external power source. Also, it is strongly recommended to use only Motorola original batteries in order to not cause any damage to the phone.
  1. Motorola V180 Battery Replacement, Battery: Schritt 1, Bild 1 von 3 Motorola V180 Battery Replacement, Battery: Schritt 1, Bild 2 von 3 Motorola V180 Battery Replacement, Battery: Schritt 1, Bild 3 von 3
    • Completely power off the Motorola V180.
    • Flip the phone over to its back side.
    • Press down the button and slide off the back cover.
    • Remove the old battery.
Abschluss
Tyler Knisley
1 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 6-16, Maness Spring 2010 Mitglied von Cal Poly, Team 6-16, Maness Spring 2010
CPSU-MANESS-S10S6G16
4 Mitglieder
13 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 12
Insgesamt: 2,647
