Zum Hauptinhalt wechseln
Motorola V180 Motherboard Replacement
Tyler Knisley
Tyler Knisley und 9 weitere Mitwirkende
Zuletzt aktualisiert am July 10, 2024
20 - 30 Minuten
Mittel
Studierende im Gange!
Schritt Schnipp Schnapp
The following instructions will guide you through the repair of your Motorola V180 Motherboard. The Motorola V180 Motherboard should be replaced when it becomes unresponsive or overheats. Replacing the motherboard should allow the Motorola to function like usual. This task does not require any special skills however, be careful as some parts do easily fall off.
Was du brauchst
Werkzeuge
  1. Motorola V180 Motherboard Replacement, Battery: Schritt 1, Bild 1 von 3 Motorola V180 Motherboard Replacement, Battery: Schritt 1, Bild 2 von 3 Motorola V180 Motherboard Replacement, Battery: Schritt 1, Bild 3 von 3
    • Completely power off the Motorola V180.
    • Flip the phone over to its back side.
    • Press down the button and slide off the back cover.
    • Remove the old battery.
  2. Motorola V180 Motherboard Replacement, Motherboard: Schritt 2, Bild 1 von 3 Motorola V180 Motherboard Replacement, Motherboard: Schritt 2, Bild 2 von 3 Motorola V180 Motherboard Replacement, Motherboard: Schritt 2, Bild 3 von 3
    • Power off the Motorola V180.
    • Hold down the button and slide off the back cover.
    • Remove the battery.
  3. Motorola V180 Motherboard Replacement: Schritt 3, Bild 1 von 3 Motorola V180 Motherboard Replacement: Schritt 3, Bild 2 von 3 Motorola V180 Motherboard Replacement: Schritt 3, Bild 3 von 3
    • Use your T6 Torx Screwdriver to unscrew the four screws located on the back of the phone.
    • Remove the SIM card located on the back of the phone.
    • A ribbon near the antenna is still attached to the motherboard. Do not break this ribbon.
  4. Motorola V180 Motherboard Replacement: Schritt 4, Bild 1 von 2 Motorola V180 Motherboard Replacement: Schritt 4, Bild 2 von 2
    • Unclip the pronged rectangle connector ribbon attached to the motherboard.
    • Remove the motherboard.
Abschluss
Tyler Knisley
1 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 6-16, Maness Spring 2010 Mitglied von Cal Poly, Team 6-16, Maness Spring 2010
CPSU-MANESS-S10S6G16
4 Mitglieder
13 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 5
Insgesamt: 2,023
