Motorola V400 Main Screen Replacement
Einleitung
Zu Schritt 1 der AnleitungThis guide will instruct you how to remove and successfully replace the main screen on the phone.
Was du brauchst
Werkzeuge
Mehr anzeigen …
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Remove the 4 stoppers surrounding the main screen with tweezers.
Use a Torx T-6 Screwdriver to unscrew the 4 screws around the screen.
Use a plastic opening tool to separate outer shell from metal interior cover.
Use plastic opening tool to to separate inner metal cover from the circuit board. Apply pressure to remove the piece.
Apply pressure to remove the screen from its adhesive backing on the plastic.
Place new screen on the phone.
