Zum Hauptinhalt wechseln
Motorola V551 Keypad Replacement
gregatron
gregatron und 6 weitere Mitwirkende
Zuletzt aktualisiert am June 23, 2022
20 Minuten
Mittel
This is a guide showing how to replace and repair the keypad of the phone.
Was du brauchst
Werkzeuge
Mehr anzeigen …
  1. Motorola V551 Keypad Replacement, Battery: Schritt 1, Bild 1 von 2 Motorola V551 Keypad Replacement, Battery: Schritt 1, Bild 2 von 2
    • Press down on the chrome button on the bottom of the chassis. Simultaneously slide the back cover down, away from the phone.
  2. Motorola V551 Keypad Replacement: Schritt 2, Bild 1 von 1
    • Lever the battery out by pressing upwards on the bottom corners of the battery.
  3. Motorola V551 Keypad Replacement, Circuit Board: Schritt 3, Bild 1 von 3 Motorola V551 Keypad Replacement, Circuit Board: Schritt 3, Bild 2 von 3 Motorola V551 Keypad Replacement, Circuit Board: Schritt 3, Bild 3 von 3
    • Remove the rubber screw covers using a plastic spudger.
    • Use a T6 Torx screwdriver to remove the screws underneath the rubber screw covers.
  4. Motorola V551 Keypad Replacement: Schritt 4, Bild 1 von 1
    • Unscrew the antenna.
  5. Motorola V551 Keypad Replacement: Schritt 5, Bild 1 von 3 Motorola V551 Keypad Replacement: Schritt 5, Bild 2 von 3 Motorola V551 Keypad Replacement: Schritt 5, Bild 3 von 3
    • Gently release the two latches using an opening tool.
    • The plastic latches are very fragile. Don’t use excessive force or they might break.
    • Pry off the back panel by wedging an opening tool into the crevice between the back panel and the circuit board.
    • Lift the back panel off of the phone.
  6. Motorola V551 Keypad Replacement: Schritt 6, Bild 1 von 2 Motorola V551 Keypad Replacement: Schritt 6, Bild 2 von 2
    • Loosen the copper circuit board connection with an opening tool.
    • Gently lift the copper connection.
  7. Motorola V551 Keypad Replacement: Schritt 7, Bild 1 von 3 Motorola V551 Keypad Replacement: Schritt 7, Bild 2 von 3 Motorola V551 Keypad Replacement: Schritt 7, Bild 3 von 3
    • Lift up and pull out the pressure pad from under the buttons on the side of the chassis.
    • Gently lift the motherboard off of the front panel.
  8. Motorola V551 Keypad Replacement, Keypad: Schritt 8, Bild 1 von 3 Motorola V551 Keypad Replacement, Keypad: Schritt 8, Bild 2 von 3 Motorola V551 Keypad Replacement, Keypad: Schritt 8, Bild 3 von 3
    • Push both side keys in so they are not sticking out of the phone.
    • Remove the keypad.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
gregatron
105 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 6-6, Maness Fall 2009 Mitglied von Cal Poly, Team 6-6, Maness Fall 2009
CPSU-MANESS-F09S6G6
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 6
Insgesamt: 2,103
