Zum Hauptinhalt wechseln
Motorola V60s Button Key Board Replacement
Eric Freeman
Eric Freeman und 6 weitere Mitwirkende
Zuletzt aktualisiert am January 20, 2025
Keine Schätzung
Mittel
Falsche Werkzeuge
Bessere Einleitung
Fehlende Angaben
This guide describes how to replace the button key board, or the processor that interprets key pad information.
Was du brauchst
Ersatzteile
Werkzeuge
Mehr anzeigen …
  1. Motorola V60s Button Key Board Replacement, Battery: Schritt 1, Bild 1 von 3 Motorola V60s Button Key Board Replacement, Battery: Schritt 1, Bild 2 von 3 Motorola V60s Button Key Board Replacement, Battery: Schritt 1, Bild 3 von 3
    • Push in release lever towards top of phone, then use blue spudger to pry case off.
    • After case is removed from the back of the phone, you can simply use your hands to take it the rest of the way off.
    • Set cover aside in a safe location.
  2. Motorola V60s Button Key Board Replacement: Schritt 2, Bild 1 von 2 Motorola V60s Button Key Board Replacement: Schritt 2, Bild 2 von 2
    • Carefully grab battery towards bottom of phone.
    • Lift from bottom and take out of phone, set aside in a safe location.
  3. Motorola V60s Button Key Board Replacement, Motherboard: Schritt 3, Bild 1 von 2 Motorola V60s Button Key Board Replacement, Motherboard: Schritt 3, Bild 2 von 2
    • Remove the four corner screws with a T6 screwdriver.
    • The two top screws are short and silver. The two bottom screws are black and long.
  4. Motorola V60s Button Key Board Replacement: Schritt 4, Bild 1 von 3 Motorola V60s Button Key Board Replacement: Schritt 4, Bild 2 von 3 Motorola V60s Button Key Board Replacement: Schritt 4, Bild 3 von 3
    • Use a spudger to gently pry off back chassis. Wedge the spudger in crevice between back panel and phone and lift.
  5. Motorola V60s Button Key Board Replacement: Schritt 5, Bild 1 von 3 Motorola V60s Button Key Board Replacement: Schritt 5, Bild 2 von 3 Motorola V60s Button Key Board Replacement: Schritt 5, Bild 3 von 3
    • Starting from left side of phone, remove side buttons and place aside.
    • There are three buttons. One on each side, and the top.
    • Return phone to starting orientation when done.
  6. Motorola V60s Button Key Board Replacement: Schritt 6, Bild 1 von 3 Motorola V60s Button Key Board Replacement: Schritt 6, Bild 2 von 3 Motorola V60s Button Key Board Replacement: Schritt 6, Bild 3 von 3
    • Gently remove orange ribbon cable by prying up with spudger.
  7. Motorola V60s Button Key Board Replacement: Schritt 7, Bild 1 von 2 Motorola V60s Button Key Board Replacement: Schritt 7, Bild 2 von 2
    • Use a spudger to pry up logic board by wedging in between logic board and chassis and lifting.
    • Orange ribbon cable is fragile and can be broken.
  8. Motorola V60s Button Key Board Replacement, Button Key Board: Schritt 8, Bild 1 von 2 Motorola V60s Button Key Board Replacement, Button Key Board: Schritt 8, Bild 2 von 2
    • Insert an opening tool under the button board and gently lift.
Abschluss
Eric Freeman
10 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 8-48, Regan Winter 2010 Mitglied von Cal Poly, Team 8-48, Regan Winter 2010
CPSU-REGAN-W10S8G48
4 Mitglieder
13 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 1,360
