Zum Hauptinhalt wechseln
Motorola V60s Button Key Pad Replacement
Eric Freeman
Eric Freeman und 6 weitere Mitwirkende
Zuletzt aktualisiert am January 20, 2025
Keine Schätzung
Mittel
Falsche Werkzeuge
Aufzählungszeichen!
Fehlende Angaben
This guide will describe how to replace the numbered cover buttons in the in-hand partition of the Motorola V60.
Was du brauchst
Werkzeuge
Mehr anzeigen …
  1. Motorola V60s Button Key Pad Replacement, Battery: Schritt 1, Bild 1 von 3 Motorola V60s Button Key Pad Replacement, Battery: Schritt 1, Bild 2 von 3 Motorola V60s Button Key Pad Replacement, Battery: Schritt 1, Bild 3 von 3
    • Push in release lever towards top of phone, then use blue spudger to pry case off.
    • After case is removed from the back of the phone, you can simply use your hands to take it the rest of the way off.
    • Set cover aside in a safe location.
  2. Motorola V60s Button Key Pad Replacement: Schritt 2, Bild 1 von 2 Motorola V60s Button Key Pad Replacement: Schritt 2, Bild 2 von 2
    • Carefully grab battery towards bottom of phone.
    • Lift from bottom and take out of phone, set aside in a safe location.
  3. Motorola V60s Button Key Pad Replacement, Motherboard: Schritt 3, Bild 1 von 2 Motorola V60s Button Key Pad Replacement, Motherboard: Schritt 3, Bild 2 von 2
    • Remove the four corner screws with a T6 screwdriver.
    • The two top screws are short and silver. The two bottom screws are black and long.
  4. Motorola V60s Button Key Pad Replacement: Schritt 4, Bild 1 von 3 Motorola V60s Button Key Pad Replacement: Schritt 4, Bild 2 von 3 Motorola V60s Button Key Pad Replacement: Schritt 4, Bild 3 von 3
    • Use a spudger to gently pry off back chassis. Wedge the spudger in crevice between back panel and phone and lift.
  5. Motorola V60s Button Key Pad Replacement: Schritt 5, Bild 1 von 3 Motorola V60s Button Key Pad Replacement: Schritt 5, Bild 2 von 3 Motorola V60s Button Key Pad Replacement: Schritt 5, Bild 3 von 3
    • Starting from left side of phone, remove side buttons and place aside.
    • There are three buttons. One on each side, and the top.
    • Return phone to starting orientation when done.
  6. Motorola V60s Button Key Pad Replacement: Schritt 6, Bild 1 von 3 Motorola V60s Button Key Pad Replacement: Schritt 6, Bild 2 von 3 Motorola V60s Button Key Pad Replacement: Schritt 6, Bild 3 von 3
    • Gently remove orange ribbon cable by prying up with spudger.
  7. Motorola V60s Button Key Pad Replacement: Schritt 7, Bild 1 von 2 Motorola V60s Button Key Pad Replacement: Schritt 7, Bild 2 von 2
    • Use a spudger to pry up logic board by wedging in between logic board and chassis and lifting.
    • Orange ribbon cable is fragile and can be broken.
  8. Motorola V60s Button Key Pad Replacement, Button Key Board: Schritt 8, Bild 1 von 2 Motorola V60s Button Key Pad Replacement, Button Key Board: Schritt 8, Bild 2 von 2
    • Insert an opening tool under the button board and gently lift.
  9. Motorola V60s Button Key Pad Replacement, Button Key Pad: Schritt 9, Bild 1 von 2 Motorola V60s Button Key Pad Replacement, Button Key Pad: Schritt 9, Bild 2 von 2
    • Life button keypad with spudger and set aside.
Abschluss
Eric Freeman
10 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 8-48, Regan Winter 2010 Mitglied von Cal Poly, Team 8-48, Regan Winter 2010
CPSU-REGAN-W10S8G48
4 Mitglieder
13 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 3,041
