Zum Hauptinhalt wechseln
Motorola i710 Charger Plug Replacement
Was du brauchst
  1. Motorola i710 Charger Plug Replacement, Battery Cover: Schritt 1, Bild 1 von 2 Motorola i710 Charger Plug Replacement, Battery Cover: Schritt 1, Bild 2 von 2
    • Slide the cover release button towards the bottom of the phone
    • Once the battery cover pops up, slide the cover towards the top of the phone and lift up.
  2. Motorola i710 Charger Plug Replacement, Battery: Schritt 2, Bild 1 von 1
    • Push the battery towards the top of the phone and lift up.
  3. Motorola i710 Charger Plug Replacement, Back Casing: Schritt 3, Bild 1 von 3 Motorola i710 Charger Plug Replacement, Back Casing: Schritt 3, Bild 2 von 3 Motorola i710 Charger Plug Replacement, Back Casing: Schritt 3, Bild 3 von 3
    • With a T5 screwdriver, unscrew the four T5 sized screws that hold the case back cover onto the rest of the case.
    • Remove the plastic case back cover by gently pulling it away from the body of the phone, starting at one edge and working your way down to the other.
  4. Motorola i710 Charger Plug Replacement, Charger Plug: Schritt 4, Bild 1 von 1
    • Once you have taken off the back cover of the phone, the charger tab can be lifted out of position on the back cover.
Abschluss
Clemson, Team 14-2, Benson Fall 2012 Mitglied von Clemson, Team 14-2, Benson Fall 2012
CLEM-BENSON-F12S14G2
4 Mitglieder
17 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 16
Letzte 30 Tage: 54
Insgesamt: 596
