Motorola i850 LCD Screen Replacement
Einleitung
Zu Schritt 1 der AnleitungReplacement of malfunctioning LCD screen.
Was du brauchst
Open the flip cover of the phone with the LCD screen facing towards you.
Insert a Spudger into the side crack of the flip cover and slowly separate the phone cover from the case.
Gently separate the flip cover case from the phone with your hands when the crack is wide enough.
Partially close the flip cover of the phone in order to take off the outer case.
Place your thumb underneath the protective metal covering to remove it from the phone.
Remove the LCD board from the phone by grabbing the bottom side of the LCD board.
