Zum Hauptinhalt wechseln
Nerf N-Strike Elite Retaliator Spring Replacement
ericharman
ericharman und 5 weitere Mitwirkende
Zuletzt aktualisiert am May 21, 2019
20 Minuten
Mittel
Benötigt Mehr Bilder
A fatigued spring can be detrimental to your blaster’s performance. This guide shows how to disassemble the blaster to replace this component. There many small components such as screws and springs that will be removed in this procedure. Be sure to record their locations for easy reassembly.
Was du brauchst
Werkzeuge
  1. Nerf N-Strike Elite Retaliator Spring Replacement, Case Disassembly: Schritt 1, Bild 1 von 1
    • While holding the blaster, rotate the barrel assembly in the counter-clockwise direction and pull away from the blaster.
  2. Nerf N-Strike Elite Retaliator Spring Replacement: Schritt 2, Bild 1 von 1
    • Remove the stock of the blaster by pushing the orange tabs downward while pulling the stock away from the blaster.
  3. Nerf N-Strike Elite Retaliator Spring Replacement: Schritt 3, Bild 1 von 1
    • Remove the magazine from the blaster by forcing the sliding mechanism backwards, pushing the orange tabs downward, and pulling the magazine away.
  4. Nerf N-Strike Elite Retaliator Spring Replacement: Schritt 4, Bild 1 von 2 Nerf N-Strike Elite Retaliator Spring Replacement: Schritt 4, Bild 2 von 2
    • Remove the stock attachment point by removing the two 8mm Phillips head screws.
  5. Nerf N-Strike Elite Retaliator Spring Replacement: Schritt 5, Bild 1 von 2 Nerf N-Strike Elite Retaliator Spring Replacement: Schritt 5, Bild 2 von 2
    • Remove the eleven 8mm and two 10mm Phillips head screws from the left side of the blaster, and carefully remove the outer casing.
    • Two of the screws must be removed with the sliding mechanism in the forward position. Another two must be removed with the sliding mechanism in the back position.
    • There are several springs that may become displaced during this procedure. Proceed with the utmost caution.
  6. Nerf N-Strike Elite Retaliator Spring Replacement, Remove Old Firing Spring: Schritt 6, Bild 1 von 2 Nerf N-Strike Elite Retaliator Spring Replacement, Remove Old Firing Spring: Schritt 6, Bild 2 von 2
    • The spring may be compressed. If so, carefully release spring pressure before proceeding.
    • While holding down the white Plunger tube, pull the spring backwards to remove it from the blaster.
Abschluss
11 weitere Personen haben diese Anleitung absolviert.
ericharman
1.422 Reputation
5 Anleitungen geschrieben
2 Kommentare
how do I remove the screws that you have to pull back the sliding mechanism if it cant be pulled back
Ryan Zhang - Antwort
can i use a nerf kronos spring
jordan - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 22
Insgesamt: 12,928
