Zum Hauptinhalt wechseln
Nerf Recon CS-6 Trigger Replacement
Pam Ruffner
Pam Ruffner und 2 weitere Mitwirkende
Zuletzt aktualisiert am January 10, 2015
20 - 30 Minuten
Mittel
Bessere Einleitung
Was du brauchst
Werkzeuge
  1. Nerf Recon CS-6 Trigger Replacement, Remove Magazine: Schritt 1, Bild 1 von 1
    • Skip this step if magazine is already removed.
    • Pull slide back.
    • Pull backwards on release buttons and slide magazine out.
    • Push slide back forward and pull trigger.
  2. Nerf Recon CS-6 Trigger Replacement, Remove Visible Screws: Schritt 2, Bild 1 von 1
    • Use the Phillips #0 Screwdriver to remove these 9 screws.
    • All screws marked in red are 9.6 mm Phillips #0 screws.
    • Note that left most screw is longer than the rest and is a 18.6 mm Phillips #0 screw.
  3. Nerf Recon CS-6 Trigger Replacement, Remove Hidden Screws: Schritt 3, Bild 1 von 2 Nerf Recon CS-6 Trigger Replacement, Remove Hidden Screws: Schritt 3, Bild 2 von 2
    • Pull slide back to reveal more screws.
    • Remove these 2 screws.
    • Push slide forward.
    • Pull trigger to release compression of the main spring.
    • Screws are 9.6 mm Phillips #0.
    • Pulling the trigger will keep spring from launching out of the gun when the two halves are separated.
  4. Nerf Recon CS-6 Trigger Replacement, Remove Plunger Cap: Schritt 4, Bild 1 von 1
    • Remove the screws on the plunger cap.
    • Tug the plunger cap off.
  5. Nerf Recon CS-6 Trigger Replacement, Remove Slide Screws: Schritt 5, Bild 1 von 1
    • Remove the 2 screws on the slide.
    • Hold the two halves of the gun together to prevent any springs from launching out.
  6. Nerf Recon CS-6 Trigger Replacement, Split the Gun in Half: Schritt 6, Bild 1 von 2 Nerf Recon CS-6 Trigger Replacement, Split the Gun in Half: Schritt 6, Bild 2 von 2
    • Pull the gun apart at the middle seam.
    • Watch for any springs that might launch out.
  7. Nerf Recon CS-6 Trigger Replacement, Remove Trigger: Schritt 7, Bild 1 von 1
    • Lift trigger up out of the gun.
    • From here, the trigger or the trigger spring can be replaced.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Pam Ruffner
1.002 Reputation
3 Anleitungen geschrieben
Baylor, Team 8-14, Williams Fall 2014 Mitglied von Baylor, Team 8-14, Williams Fall 2014
BU-WILLIAMS-F14S8G14
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 9
Insgesamt: 4,008
