Einleitung
You will need a thin durable tool to get the back cover off first. A guitar pick works well if you don't have a plastic opening tool. The parts are very delicate, so use caution when removing the back cover and inner parts.
Werkzeuge
Ersatzteile
Kein Ersatzteil erforderlich.
Use the plastic opening tool to remove the back cover. Carefully slide the tool between the front glass and back cover.
Slide the tool along the edge to work the back cover off.
Remove the tape covering the motherboard.
Remove the silver tape holding the white ribbon cables to the battery.
Use a spudger to carefully disconnect the battery connector from the motherboard.
Use a spudger to lift up the black bar on the two ZIF connectors located above the battery.
Pull the ribbon cables out of the connectors with tweezers or two fingers.
Using the flat end of a spudger, carefully work the spudger under the battery, lifting it off of the device.
Use a small Phillips screwdriver to remove the 0.116 inch screw holding the red and black wires in place on the inside of the back cover.
Use a desoldering tool to remove the solder holding the red and black speaker wires to the motherboard.
If you do not have a desoldering tool, you can use a solder gun to remove the old solder.
Use the soldering gun to solder the new speaker wires to the motherboard where the original wires were connected.
Make sure that you connect the red wire to the positive terminal on the right, and the black wire to the negative terminal on the left.
Ein weiterer Nutzer hat diese Anleitung absolviert.
