Nextbook NX008HD8G Back Panel Replacement
Einleitung
Zu Schritt 1 der AnleitungUse this guide to replace a broken back panel. Sliding the plastic opening tool between the back panel and the front glass can be difficult.
Was du brauchst
Using your finger, open the plastic tab to the right of the rear-facing camera.
Wedge your fingernail in between the back panel and the plastic tab and pull the plastic tab towards your body.
Using your finger, remove the SD card by pressing down on top of it (toward the bottom of the device) until you hear a clicking sound.
Once the card pops out, use your finger to pull the card completely out of the SD card slot.
Remove the 5 mm screw using the Phillips PH00 bit in the iFixit metal Screwdriver.
Use the plastic opening tool to separate the back panel by carefully sliding the narrow end of the tool between the front glass and back panel.
Use a second plastic opening tool to help pry the front glass from the back panel.
Use your hands to completely separate the rest of the front glass from the back panel.
3 weitere Personen haben diese Anleitung absolviert.
