Nikon 1 J5 Main PCB Replacement
Was du brauchst
Remove 2 screws
Open plastic LCD connector cover
Lift FPC connector latch
Detach LCD FPC
Left side, in connector bay, remove 2 screws.
Bottom, reomve 2 screws
Right side, remove 1 screw
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Peel tape with an isolated tool (plastic crowbar, plastic tweezers, toothpick etc). DO NOT USE metal tweezers.
Use a 2-10kohm 5W resistor to discharge flash condenser, for atleast 10 seconds.
Check voltage across 2 points. Make sure it's below 5V DC
Flash solenoid and detect
Microphones and AF assistant LED
Keypad
Switches
NFC
WiFi and Bluetooth, Lens(back)
CMOS sensor
LCD
Desolder Flash Condenser
Desolder flash xenon tube
