Zum Hauptinhalt wechseln
Nintendo Switch OLED Model Bottom Rail Replacement
Was du brauchst
  1. Nintendo Switch OLED Model Bottom Rail Replacement, Release the Joy Con controller locking tabs: Schritt 1, Bild 1 von 3 Nintendo Switch OLED Model Bottom Rail Replacement, Release the Joy Con controller locking tabs: Schritt 1, Bild 2 von 3 Nintendo Switch OLED Model Bottom Rail Replacement, Release the Joy Con controller locking tabs: Schritt 1, Bild 3 von 3
    • Before you begin this repair, make sure the device is completely powered off.
    • Press and hold down the small round button on the back of the Joy Con controller.
    • While you hold down the button, slide the controller upward.
  2. Nintendo Switch OLED Model Bottom Rail Replacement, Remove the Joy Con controllers: Schritt 2, Bild 1 von 3 Nintendo Switch OLED Model Bottom Rail Replacement, Remove the Joy Con controllers: Schritt 2, Bild 2 von 3 Nintendo Switch OLED Model Bottom Rail Replacement, Remove the Joy Con controllers: Schritt 2, Bild 3 von 3
    • Continue sliding the Joy Con upward until it's completely removed from the console.
    • Repeat this same process for the other Joy Con.
  3. Nintendo Switch OLED Model Bottom Rail Replacement, Remove the top screw: Schritt 3, Bild 1 von 2 Nintendo Switch OLED Model Bottom Rail Replacement, Remove the top screw: Schritt 3, Bild 2 von 2
    • Use a Phillips driver, or a JIS driver, to remove the 2 mm-long screw securing the top of the rear case to the frame.
    • To prevent these tight screws from stripping, apply firm downward force, work slowly, and try another JIS or Phillips driver if the screws won't come out.
  4. Nintendo Switch OLED Model Bottom Rail Replacement, Remove the bottom screws: Schritt 4, Bild 1 von 2 Nintendo Switch OLED Model Bottom Rail Replacement, Remove the bottom screws: Schritt 4, Bild 2 von 2
    • Use a Phillips driver to remove the two 2 mm-long screws securing the bottom of the rear case to the frame.
  5. Nintendo Switch OLED Model Bottom Rail Replacement, Remove the right screw: Schritt 5, Bild 1 von 2 Nintendo Switch OLED Model Bottom Rail Replacement, Remove the right screw: Schritt 5, Bild 2 von 2
    • Use a Phillips driver to remove the 3.8 mm screw securing the right Joy-Con sensor rail to the rear case.
    • To prevent these tight screws from stripping, apply firm downward force, work slowly and try another JIS 000 or PH 000 driver if the screws won't come out.
  6. Nintendo Switch OLED Model Bottom Rail Replacement, Remove the left screw: Schritt 6, Bild 1 von 2 Nintendo Switch OLED Model Bottom Rail Replacement, Remove the left screw: Schritt 6, Bild 2 von 2
    • Use a Phillips driver to remove the 3.8 mm screw securing the left Joy-Con sensor rail to the rear case.
  7. Nintendo Switch OLED Model Bottom Rail Replacement, Open the kickstand: Schritt 7, Bild 1 von 2 Nintendo Switch OLED Model Bottom Rail Replacement, Open the kickstand: Schritt 7, Bild 2 von 2
    • Use your finger to flip up the kickstand on the back of the device.
    • If there's a microSD card in the microSD card slot, remove it now before you continue to the next step.
  8. Nintendo Switch OLED Model Bottom Rail Replacement, Remove the back-side screws: Schritt 8, Bild 1 von 2 Nintendo Switch OLED Model Bottom Rail Replacement, Remove the back-side screws: Schritt 8, Bild 2 von 2
    • Use a Y00 screwdriver to remove the two 4.3 mm screws securing the rear case to the frame.
  9. Nintendo Switch OLED Model Bottom Rail Replacement, Remove the rear case: Schritt 9, Bild 1 von 3 Nintendo Switch OLED Model Bottom Rail Replacement, Remove the rear case: Schritt 9, Bild 2 von 3 Nintendo Switch OLED Model Bottom Rail Replacement, Remove the rear case: Schritt 9, Bild 3 von 3
    • Lift the rear case up from the top of the device and remove it.
    • If you're having trouble removing the case, use an opening pick to pry up the plastic clips.
  10. Nintendo Switch OLED Model Bottom Rail Replacement, Remove the shield plate's tape: Schritt 10, Bild 1 von 2 Nintendo Switch OLED Model Bottom Rail Replacement, Remove the shield plate's tape: Schritt 10, Bild 2 von 2
    • Use the flat end of a spudger to separate a corner of the tape from the shield plate.
  11. Nintendo Switch OLED Model Bottom Rail Replacement: Schritt 11, Bild 1 von 3 Nintendo Switch OLED Model Bottom Rail Replacement: Schritt 11, Bild 2 von 3 Nintendo Switch OLED Model Bottom Rail Replacement: Schritt 11, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • Use tweezers, or your fingers, to peel back and remove the tape.
    • Store the tape in a clean space for reinstallation.
  12. Nintendo Switch OLED Model Bottom Rail Replacement, Disconnect the primary Wi-Fi antenna: Schritt 12, Bild 1 von 2 Nintendo Switch OLED Model Bottom Rail Replacement, Disconnect the primary Wi-Fi antenna: Schritt 12, Bild 2 von 2
    • Use tweezers, or your fingers, to pull up and disconnect the primary Wi-Fi antenna's coaxial cable.
    • During reassembly, these can be tricky to reconnect. One at a time, hold each connector in place over its socket and press down with the flat end of a spudger. The connector should snap into place.
  13. Nintendo Switch OLED Model Bottom Rail Replacement, Reroute the primary antenna's coaxial cable: Schritt 13, Bild 1 von 3 Nintendo Switch OLED Model Bottom Rail Replacement, Reroute the primary antenna's coaxial cable: Schritt 13, Bild 2 von 3 Nintendo Switch OLED Model Bottom Rail Replacement, Reroute the primary antenna's coaxial cable: Schritt 13, Bild 3 von 3
    • Use tweezers, or your fingers, to reroute the primary antenna's coaxial cable out of its slots in the shield plate.
  14. Nintendo Switch OLED Model Bottom Rail Replacement, Unfasten the primary Wi-Fi antenna: Schritt 14, Bild 1 von 2 Nintendo Switch OLED Model Bottom Rail Replacement, Unfasten the primary Wi-Fi antenna: Schritt 14, Bild 2 von 2
    • Use a Phillips driver to remove the two 4.4 mm screws securing the primary Wi-Fi antenna to the shield plate.
  15. Nintendo Switch OLED Model Bottom Rail Replacement, Remove the primary Wi-Fi antenna: Schritt 15, Bild 1 von 3 Nintendo Switch OLED Model Bottom Rail Replacement, Remove the primary Wi-Fi antenna: Schritt 15, Bild 2 von 3 Nintendo Switch OLED Model Bottom Rail Replacement, Remove the primary Wi-Fi antenna: Schritt 15, Bild 3 von 3
    • Insert an opening pick between the primary Wi-Fi antenna and the shield plate.
    • Pry up with the pick to separate the primary Wi-Fi antenna from the shield plate.
  16. Nintendo Switch OLED Model Bottom Rail Replacement: Schritt 16, Bild 1 von 2 Nintendo Switch OLED Model Bottom Rail Replacement: Schritt 16, Bild 2 von 2
    • Remove the primary Wi-Fi antenna.
  17. Nintendo Switch OLED Model Bottom Rail Replacement, Disconnect the secondary Wi-Fi antenna: Schritt 17, Bild 1 von 2 Nintendo Switch OLED Model Bottom Rail Replacement, Disconnect the secondary Wi-Fi antenna: Schritt 17, Bild 2 von 2
    • Use tweezers, or your fingers, to pull up and disconnect the secondary Wi-Fi antenna's coaxial cable.
  18. Nintendo Switch OLED Model Bottom Rail Replacement, Reroute the secondary Wi-Fi antenna's coaxial cable: Schritt 18, Bild 1 von 2 Nintendo Switch OLED Model Bottom Rail Replacement, Reroute the secondary Wi-Fi antenna's coaxial cable: Schritt 18, Bild 2 von 2
    • Use the point of a spudger to reroute the secondary Wi-Fi antenna's coaxial cable from its slot in the frame.
  19. Nintendo Switch OLED Model Bottom Rail Replacement, Unfasten the secondary Wi-Fi antenna: Schritt 19, Bild 1 von 2 Nintendo Switch OLED Model Bottom Rail Replacement, Unfasten the secondary Wi-Fi antenna: Schritt 19, Bild 2 von 2
    • Use a Phillips driver to remove the 4.4 mm screw securing the secondary Wi-Fi antenna to the shield plate.
  20. Nintendo Switch OLED Model Bottom Rail Replacement, Remove the secondary Wi-Fi antenna: Schritt 20, Bild 1 von 3 Nintendo Switch OLED Model Bottom Rail Replacement, Remove the secondary Wi-Fi antenna: Schritt 20, Bild 2 von 3 Nintendo Switch OLED Model Bottom Rail Replacement, Remove the secondary Wi-Fi antenna: Schritt 20, Bild 3 von 3
    • Insert an opening pick between the secondary Wi-Fi antenna and the shield plate.
    • Pry up with the pick to separate the secondary Wi-Fi antenna from the shield plate.
    • Don't attempt to completely remove the antenna yet, as its coaxial cable is still routed through the frame.
  21. Nintendo Switch OLED Model Bottom Rail Replacement: Schritt 21, Bild 1 von 3 Nintendo Switch OLED Model Bottom Rail Replacement: Schritt 21, Bild 2 von 3 Nintendo Switch OLED Model Bottom Rail Replacement: Schritt 21, Bild 3 von 3
    • Use the point of a spudger to reroute the secondary Wi-Fi antenna's coaxial cable out of its slot in the frame.
    • Remove the secondary Wi-Fi antenna.
  22. Nintendo Switch OLED Model Bottom Rail Replacement, Unfasten the shield plate: Schritt 22, Bild 1 von 2 Nintendo Switch OLED Model Bottom Rail Replacement, Unfasten the shield plate: Schritt 22, Bild 2 von 2
    • Use a Phillips driver to remove the six 4.4 mm screws securing the shield plate to the frame.
  23. Nintendo Switch OLED Model Bottom Rail Replacement: Schritt 23, Bild 1 von 2 Nintendo Switch OLED Model Bottom Rail Replacement: Schritt 23, Bild 2 von 2
    • Use your fingers to lift the top of the shield plate up and away from the frame.
    • You may feel a bit of resistance. This is normal, since the shield plate is slightly bonded to the heat sink with thermal paste.
    • Remove the shield plate.
    • A thick pink thermal compound bridges the gap between the shield plate and the copper heat sink underneath. Whenever the shield plate is removed, refer to our thermal paste guide to remove the old thermal compound and replace it with an appropriate compound, such as K5 Pro, during reassembly.
  24. Nintendo Switch OLED Model Bottom Rail Replacement, Disconnect the battery: Schritt 24, Bild 1 von 2 Nintendo Switch OLED Model Bottom Rail Replacement, Disconnect the battery: Schritt 24, Bild 2 von 2
    • Use the point of a spudger to pry up and disconnect the battery.
  25. Nintendo Switch OLED Model Bottom Rail Replacement, Remove the tape: Schritt 25, Bild 1 von 3 Nintendo Switch OLED Model Bottom Rail Replacement, Remove the tape: Schritt 25, Bild 2 von 3 Nintendo Switch OLED Model Bottom Rail Replacement, Remove the tape: Schritt 25, Bild 3 von 3
    • Use tweezers, or your fingers, to remove the piece of tape obscuring the daughterboard's screw.
  26. Nintendo Switch OLED Model Bottom Rail Replacement, Unfasten the daughterboard: Schritt 26, Bild 1 von 2 Nintendo Switch OLED Model Bottom Rail Replacement, Unfasten the daughterboard: Schritt 26, Bild 2 von 2
    • Use a Phillips driver to remove the 4 mm screw securing the daughterboard to the frame.
  27. Nintendo Switch OLED Model Bottom Rail Replacement, Remove the daughterboard: Schritt 27, Bild 1 von 3 Nintendo Switch OLED Model Bottom Rail Replacement, Remove the daughterboard: Schritt 27, Bild 2 von 3 Nintendo Switch OLED Model Bottom Rail Replacement, Remove the daughterboard: Schritt 27, Bild 3 von 3
    • The bottom of the daughterboard is connected to the motherboard via a press connector.
    • Insert a spudger between the edge of the daughterboard and the motherboard.
    • Pry up with the spudger to disconnect the press connector and separate the daughterboard from the frame.
    • Remove the daughterboard.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  28. Nintendo Switch OLED Model Bottom Rail Replacement, Unfasten the heat sink: Schritt 28, Bild 1 von 2 Nintendo Switch OLED Model Bottom Rail Replacement, Unfasten the heat sink: Schritt 28, Bild 2 von 2
    • Use a Phillips driver to remove the three 3 mm screws securing the heat sink to the motherboard.
  29. Nintendo Switch OLED Model Bottom Rail Replacement, Remove the heat sink: Schritt 29, Bild 1 von 2 Nintendo Switch OLED Model Bottom Rail Replacement, Remove the heat sink: Schritt 29, Bild 2 von 2
    • Insert a spudger between the heat sink's bracket and the motherboard.
    • Pry up with the spudger to separate the heat sink from the motherboard.
    • You may feel a bit of resistance. This is normal, since the heat sink is slightly bonded to the CPU with thermal paste.
  30. Nintendo Switch OLED Model Bottom Rail Replacement: Schritt 30, Bild 1 von 3 Nintendo Switch OLED Model Bottom Rail Replacement: Schritt 30, Bild 2 von 3 Nintendo Switch OLED Model Bottom Rail Replacement: Schritt 30, Bild 3 von 3
    • Insert a spudger in the gap between the fan and the heat sink.
    • Pry up with the spudger to separate the heat sink from the adhesive beneath it.
    • Remove the heat sink.
    • Clean off the old thermal paste from the heat sink and CPU using high-concentration (90% or higher) isopropyl alcohol and a microfiber cloth. Apply new thermal paste to the CPU before reassembly.
  31. Nintendo Switch OLED Model Bottom Rail Replacement, Disconnect the fan's ZIF connector: Schritt 31, Bild 1 von 2 Nintendo Switch OLED Model Bottom Rail Replacement, Disconnect the fan's ZIF connector: Schritt 31, Bild 2 von 2
    • Use the tip of a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the fan cable's ZIF connector.
  32. Nintendo Switch OLED Model Bottom Rail Replacement: Schritt 32, Bild 1 von 2 Nintendo Switch OLED Model Bottom Rail Replacement: Schritt 32, Bild 2 von 2
    • Use a pair of tweezers to pull the fan cable straight out of its connector on the motherboard.
  33. Nintendo Switch OLED Model Bottom Rail Replacement, Unfasten the fan: Schritt 33, Bild 1 von 2 Nintendo Switch OLED Model Bottom Rail Replacement, Unfasten the fan: Schritt 33, Bild 2 von 2
    • Use a Phillips driver to remove the three 3 mm screws securing the fan to the frame.
  34. Nintendo Switch OLED Model Bottom Rail Replacement, Remove the fan: Schritt 34, Bild 1 von 3 Nintendo Switch OLED Model Bottom Rail Replacement, Remove the fan: Schritt 34, Bild 2 von 3 Nintendo Switch OLED Model Bottom Rail Replacement, Remove the fan: Schritt 34, Bild 3 von 3
    • Use a spudger to lift the fan out straight out of the frame.
    • Remove the fan.
  35. Nintendo Switch OLED Model Bottom Rail Replacement, Disconnect the power button board's ZIF connector: Schritt 35, Bild 1 von 2 Nintendo Switch OLED Model Bottom Rail Replacement, Disconnect the power button board's ZIF connector: Schritt 35, Bild 2 von 2
    • Use an opening tool, spudger, or your fingernail to flip up the small, hinged locking flap on the power button board's ZIF connector.
  36. Nintendo Switch OLED Model Bottom Rail Replacement: Schritt 36, Bild 1 von 2 Nintendo Switch OLED Model Bottom Rail Replacement: Schritt 36, Bild 2 von 2
    • Use a pair of tweezers to pull the power button board cable straight out of its connector on the motherboard.
  37. Nintendo Switch OLED Model Bottom Rail Replacement, Disconnect the right Joy-Con sensor rail's ZIF connector: Schritt 37, Bild 1 von 2 Nintendo Switch OLED Model Bottom Rail Replacement, Disconnect the right Joy-Con sensor rail's ZIF connector: Schritt 37, Bild 2 von 2
    • Use an opening tool, spudger, or your fingernail to flip up the small, hinged locking flap on the right Joy-Con sensor rail's ZIF connector.
  38. Nintendo Switch OLED Model Bottom Rail Replacement: Schritt 38, Bild 1 von 2 Nintendo Switch OLED Model Bottom Rail Replacement: Schritt 38, Bild 2 von 2
    • Use a pair of tweezers to pull the right Joy-Con sensor rail's cable straight out of its connector on the motherboard.
  39. Nintendo Switch OLED Model Bottom Rail Replacement, Disconnect the display's ZIF connector: Schritt 39, Bild 1 von 2 Nintendo Switch OLED Model Bottom Rail Replacement, Disconnect the display's ZIF connector: Schritt 39, Bild 2 von 2
    • Use an opening tool, spudger, or your fingernail to flip up the hinged locking flap on the display's ZIF connector.
  40. Nintendo Switch OLED Model Bottom Rail Replacement: Schritt 40, Bild 1 von 2 Nintendo Switch OLED Model Bottom Rail Replacement: Schritt 40, Bild 2 von 2
    • Use a pair of tweezers to pull the display cable straight out of its connector on the motherboard.
  41. Nintendo Switch OLED Model Bottom Rail Replacement, Disconnect the left speaker: Schritt 41, Bild 1 von 3 Nintendo Switch OLED Model Bottom Rail Replacement, Disconnect the left speaker: Schritt 41, Bild 2 von 3 Nintendo Switch OLED Model Bottom Rail Replacement, Disconnect the left speaker: Schritt 41, Bild 3 von 3
    • Use blunt tweezers, or your fingers, to pull the left speaker's JST connector out of its socket.
  42. Nintendo Switch OLED Model Bottom Rail Replacement, Disconnect the right speaker: Schritt 42, Bild 1 von 3 Nintendo Switch OLED Model Bottom Rail Replacement, Disconnect the right speaker: Schritt 42, Bild 2 von 3 Nintendo Switch OLED Model Bottom Rail Replacement, Disconnect the right speaker: Schritt 42, Bild 3 von 3
    • Use blunt tweezers, or your fingers, to pull the right speaker's JST connector out of its socket.
  43. Nintendo Switch OLED Model Bottom Rail Replacement, Disconnect the left Joy-Con sensor rail's ZIF connector: Schritt 43, Bild 1 von 2 Nintendo Switch OLED Model Bottom Rail Replacement, Disconnect the left Joy-Con sensor rail's ZIF connector: Schritt 43, Bild 2 von 2
  44. Nintendo Switch OLED Model Bottom Rail Replacement: Schritt 44, Bild 1 von 3 Nintendo Switch OLED Model Bottom Rail Replacement: Schritt 44, Bild 2 von 3 Nintendo Switch OLED Model Bottom Rail Replacement: Schritt 44, Bild 3 von 3
    • Use a pair of tweezers to pull the left Joy-Con sensor rail's cable straight out of its connector on the motherboard.
  45. Nintendo Switch OLED Model Bottom Rail Replacement, Unfasten the motherboard: Schritt 45, Bild 1 von 2 Nintendo Switch OLED Model Bottom Rail Replacement, Unfasten the motherboard: Schritt 45, Bild 2 von 2
    • Use a Phillips driver to remove the five screws securing the midframe to the frame:
    • Three 3 mm screws
    • Two 4.4 mm screws
  46. Nintendo Switch OLED Model Bottom Rail Replacement, Remove the motherboard: Schritt 46, Bild 1 von 3 Nintendo Switch OLED Model Bottom Rail Replacement, Remove the motherboard: Schritt 46, Bild 2 von 3 Nintendo Switch OLED Model Bottom Rail Replacement, Remove the motherboard: Schritt 46, Bild 3 von 3
    • Insert a spudger between the motherboard and the frame.
    • Pry up with the spudger to separate the motherboard from the frame.
    • Remove the motherboard.
  47. Nintendo Switch OLED Model Bottom Rail Replacement, Unfasten the bottom rail: Schritt 47, Bild 1 von 2 Nintendo Switch OLED Model Bottom Rail Replacement, Unfasten the bottom rail: Schritt 47, Bild 2 von 2
    • Use a Phillips driver to remove the two 3 mm screws securing the bottom rail to the frame.
  48. Nintendo Switch OLED Model Bottom Rail Replacement, Remove the bottom rail: Schritt 48, Bild 1 von 2 Nintendo Switch OLED Model Bottom Rail Replacement, Remove the bottom rail: Schritt 48, Bild 2 von 2
    • Remove the bottom rail.
Abschluss
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch OLED Answers community for help.
Eine weitere Person hat diese Anleitung absolviert.
Alex Diaz-Kokaisl
161.984 Reputation
769 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
118 Mitglieder
19.413 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 9
Letzte 7 Tage: 42
Letzte 30 Tage: 213
Insgesamt: 6,298
