Zum Hauptinhalt wechseln
Panasonic Bread Bakery SD-251 Display Replacement
Bango Bejla
Bango Bejla und eine weitere beteiligte Person
Zuletzt aktualisiert am August 9, 2021
15 Minuten
Mittel
Anleitung eines Community-Mitglieds
Grammatikfehler
There has been some worm under the outer shell but over the display, and so I disassembled it to clean it
  1. Panasonic Bread Bakery SD-251 Display Replacement, Preparations for work: Schritt 1, Bild 1 von 3 Panasonic Bread Bakery SD-251 Display Replacement, Preparations for work: Schritt 1, Bild 2 von 3 Panasonic Bread Bakery SD-251 Display Replacement, Preparations for work: Schritt 1, Bild 3 von 3
    • Make sure the machine is not under power and
    • remove the inner container
  2. Panasonic Bread Bakery SD-251 Display Replacement, Removing the lid: Schritt 2, Bild 1 von 3 Panasonic Bread Bakery SD-251 Display Replacement, Removing the lid: Schritt 2, Bild 2 von 3 Panasonic Bread Bakery SD-251 Display Replacement, Removing the lid: Schritt 2, Bild 3 von 3
    • Remove the screw on the left side of the hinge of the lid (whith a philips 1 screwdrive)
    • After the screw is removed, you can move the lid (in open position) to the other side and slide it off the hinge (removing the lid completely)
  3. Panasonic Bread Bakery SD-251 Display Replacement, Remove the screws from the bottom part: Schritt 3, Bild 1 von 3 Panasonic Bread Bakery SD-251 Display Replacement, Remove the screws from the bottom part: Schritt 3, Bild 2 von 3 Panasonic Bread Bakery SD-251 Display Replacement, Remove the screws from the bottom part: Schritt 3, Bild 3 von 3
    • Turn the complete machine upside down
    • Remove the four (PH1) screws from the four rubber stands.
  4. Panasonic Bread Bakery SD-251 Display Replacement: Schritt 4, Bild 1 von 3 Panasonic Bread Bakery SD-251 Display Replacement: Schritt 4, Bild 2 von 3 Panasonic Bread Bakery SD-251 Display Replacement: Schritt 4, Bild 3 von 3
    • Remove the two normal screws from the shorter sides (normal PH1 screws)
  5. Panasonic Bread Bakery SD-251 Display Replacement: Schritt 5, Bild 1 von 3 Panasonic Bread Bakery SD-251 Display Replacement: Schritt 5, Bild 2 von 3 Panasonic Bread Bakery SD-251 Display Replacement: Schritt 5, Bild 3 von 3
    • Remove the two torx screws from the longer sides (T20 S2)
  6. Panasonic Bread Bakery SD-251 Display Replacement, Reveal the inner side: Schritt 6, Bild 1 von 3 Panasonic Bread Bakery SD-251 Display Replacement, Reveal the inner side: Schritt 6, Bild 2 von 3 Panasonic Bread Bakery SD-251 Display Replacement, Reveal the inner side: Schritt 6, Bild 3 von 3
    • When all screws are removed from the bottom side, the metal cover can be simply lifted up, and the motor is visible
  7. Panasonic Bread Bakery SD-251 Display Replacement, Remove the screws from the upper side: Schritt 7, Bild 1 von 3 Panasonic Bread Bakery SD-251 Display Replacement, Remove the screws from the upper side: Schritt 7, Bild 2 von 3 Panasonic Bread Bakery SD-251 Display Replacement, Remove the screws from the upper side: Schritt 7, Bild 3 von 3
    • Turn the device back upwards
    • Remove the six (PH1) screws around the grey part (beneath the removed lid)
  8. Panasonic Bread Bakery SD-251 Display Replacement: Schritt 8, Bild 1 von 3 Panasonic Bread Bakery SD-251 Display Replacement: Schritt 8, Bild 2 von 3 Panasonic Bread Bakery SD-251 Display Replacement: Schritt 8, Bild 3 von 3
    • Remove the two (PH1) screws from the display panels side
    • one on the right side of the baker
    • one on the back of the backer
  9. Panasonic Bread Bakery SD-251 Display Replacement, Loosening the Chassis from the inner part to release hooks: Schritt 9, Bild 1 von 1
    • Try moving the metal chassis downward, holding the grey inner part, creating a tiny gap on the left side of the machine and loosening the inner part a bit
    • the right side loosens up a bit too
  10. Panasonic Bread Bakery SD-251 Display Replacement: Schritt 10, Bild 1 von 2 Panasonic Bread Bakery SD-251 Display Replacement: Schritt 10, Bild 2 von 2
    • Push the metal chassis inwards, so that the plastic hook is moved out of the metal chassis
    • This may be the hardest part
    • After the front hook is moved out, the plastic display part can be turned to the right along the shorter side
    • Turn gently, because there is a cable connecting the display with the lower (inner) part
    • There is a hook on the right side too, which is unhooked durint the turning
  11. Panasonic Bread Bakery SD-251 Display Replacement, Removing the core display: Schritt 12, Bild 1 von 2 Panasonic Bread Bakery SD-251 Display Replacement, Removing the core display: Schritt 12, Bild 2 von 2
    • Remove the (PH1) screw from the bottom part (upper side after turning out) of the display
  12. Panasonic Bread Bakery SD-251 Display Replacement: Schritt 13, Bild 1 von 2 Panasonic Bread Bakery SD-251 Display Replacement: Schritt 13, Bild 2 von 2
    • Tilt the display brick and move it towards yourself to release the hooks on the upper side of the brick
  13. Panasonic Bread Bakery SD-251 Display Replacement, Display circuit revealed: Schritt 14, Bild 1 von 1
    • Finally, the inner display and buttons can be reached and cleaned
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Bango Bejla
1.357 Reputation
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 25
Insgesamt: 677
