Zum Hauptinhalt wechseln
Philips Satinelle Plastic Cover Replacement
Madeline Casalino
Madeline Casalino und 3 weitere Mitwirkende
Zuletzt aktualisiert am July 14, 2024
5 - 10 Minuten
Leicht
Replace the epilator if the outer cover is so damaged that it becomes troublesome to hold. This is a very easy fix as it only requires you to transfer the components of the broken device into a new cover. You will need a metal spudger. Be careful not to damage any internal components as you pry apart the broken shell. This guide should take five to ten minutes to complete.
Was du brauchst
Werkzeuge
  1. Philips Satinelle Plastic Cover Replacement, Plastic Cover: Schritt 1, Bild 1 von 3 Philips Satinelle Plastic Cover Replacement, Plastic Cover: Schritt 1, Bild 2 von 3 Philips Satinelle Plastic Cover Replacement, Plastic Cover: Schritt 1, Bild 3 von 3
    • Remove the head by pushing it to the right.
  2. Philips Satinelle Plastic Cover Replacement: Schritt 2, Bild 1 von 2 Philips Satinelle Plastic Cover Replacement: Schritt 2, Bild 2 von 2
    • Use a metal spudger to pry open the casing.
    • Caution: The epilator's internal components could be damaged if you shove the spudger in too far.
  3. Philips Satinelle Plastic Cover Replacement: Schritt 3, Bild 1 von 1
    • Pull the plastic casing apart with your hands.
    • The plastic tab connecting the cover is likely going to break when you pull the device apart. This will not affect the operation of the epilator.
Abschluss
To reassemble your device, move the components from the broken shell into the new shell and follow these instructions in reverse order.
Marist, Team S1-G1, Chaterdon Fall 2018 Mitglied von Marist, Team S1-G1, Chaterdon Fall 2018
MARS-CHATERDON-F18S1G1
3 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 630
