Philips Satinelle Tweezer Replacement
Einleitung
Zu Schritt 1 der AnleitungIf the tweezers are struggling to grasp and pull out hair, it's time to replace them. Replacing the blades only requires you to disassemble the head of the epilator. You will only need a plastic opening tool or some other prying tool. Be careful when removing the tension clip. It has a tendency to shoot out at high speed when removed. This guide generally takes one to three minutes to complete.
Was du brauchst
Werkzeuge
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Hold the head of the epilator with the tweezers facing away from you.
Remove the tension clip using an opening tool.
Hold the head at an angle (this will prevent the tweezers from falling out).
Open the hinged end of the head.
Remove the old tweezers and replace them with the new tweezers.
2 weitere Personen haben diese Anleitung absolviert.
