Polaroid Onestep Close Up Shutter Switch Replacement
Einleitung
Zu Schritt 1 der AnleitungThe shutter switch is the button which is to be pressed when the user wants to capture an image. If for some reason this switch needs to be replaced, this guide will be showing how to remove the shutter switch.
Was du brauchst
Werkzeuge
Begin by opening the top of the camera (flash assembly) to a slight angle.
Next, angle the flash assembly slightly upward and pry off the connections carefully.
Slide the action button, on the bottom of the camera, to open the bottom.
Insert the blue plastic opening tool between the rear case and the plastic tabs directly under the shelf, and pry it loose.
Pull off the face plate.
After the face plate is off, the shutter switch should slide out easily.
3 weitere Personen haben diese Anleitung absolviert.
2 Kommentare
where did you get the replacement parts for this?
I’d love to find a new shutter piece..
