Zum Hauptinhalt wechseln
Polk Omni S2 Front Cover Replacement
Phoenix Dalla Costa
Phoenix Dalla Costa und 2 weitere Mitwirkende
Zuletzt aktualisiert am December 27, 2024
5 Minuten
Leicht
This guide will show you how to remove the entire front of the Polk Omni S2, which holds the two drivers, two radiators, and the buttons.
Was du brauchst
Werkzeuge
  1. Polk Omni S2 Front Cover Replacement, Front Cover: Schritt 1, Bild 1 von 1
    • Pry off the grille by pulling on the top middle part of it.
    • Remove the grille carefully, but note that it takes a large amount of force to remove. If it seems like you're bending the grille too much, try pulling on it from the bottom instead.
  2. Polk Omni S2 Front Cover Replacement: Schritt 2, Bild 1 von 3 Polk Omni S2 Front Cover Replacement: Schritt 2, Bild 2 von 3 Polk Omni S2 Front Cover Replacement: Schritt 2, Bild 3 von 3
    • Remove the eight 12 mm screws securing the front cover using a Phillips #1 screwdriver.
    • Like the grille, pull from the top middle of the gray cover and slowly remove it from the speaker, like separating a sub roll.
    • Be careful of the wires between the cover and the motherboard. If you pull the cover apart too far, you might damage these wires.
  3. Polk Omni S2 Front Cover Replacement: Schritt 3, Bild 1 von 3 Polk Omni S2 Front Cover Replacement: Schritt 3, Bild 2 von 3 Polk Omni S2 Front Cover Replacement: Schritt 3, Bild 3 von 3
    • Remove the two square cotton pieces.
    • Unplug these three wires plugged into the motherboard by gently pulling and wiggling the wires until they're unplugged. Grip the wires close to the end to avoid damaging them.
Abschluss
UMass Dartmouth, Team 1-4, Konn Fall 2024 Mitglied von UMass Dartmouth, Team 1-4, Konn Fall 2024
UMASSD-KONN-F24S1G4
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 5
Insgesamt: 49
