Zum Hauptinhalt wechseln
QSEW QS-1201 Needle Replacement
Reema
Reema und 2 weitere Mitwirkende
Zuletzt aktualisiert am March 7, 2024
5 - 10 Minuten
Mittel
Attention, tailors! This manual offers a comprehensive guide on replacing a broken needle in your QSEW QS-1201 computerized embroidery machine. While the process is relatively straightforward, the machine may seem a bit intimidating. If you're not familiar with how it works, follow this guide, and you'll be back to embroidering your favorite items in no time. Pull up your socks and give it a try!
Before you begin, power off the machine and unplug the device from the outlet.
  1. QSEW QS-1201 Needle Replacement, Needle: Schritt 1, Bild 1 von 3 QSEW QS-1201 Needle Replacement, Needle: Schritt 1, Bild 2 von 3 QSEW QS-1201 Needle Replacement, Needle: Schritt 1, Bild 3 von 3
    • Power off your machine and unplug it from the outlet.
    • This will prevent accidental activation and injury, even for experts!
  2. QSEW QS-1201 Needle Replacement: Schritt 2, Bild 1 von 2 QSEW QS-1201 Needle Replacement: Schritt 2, Bild 2 von 2
    • Have a close look at the difference between the broken needle ( left ) and the brand-new needle ( right ).
  3. QSEW QS-1201 Needle Replacement: Schritt 3, Bild 1 von 3 QSEW QS-1201 Needle Replacement: Schritt 3, Bild 2 von 3 QSEW QS-1201 Needle Replacement: Schritt 3, Bild 3 von 3
    • Locate the needle holder with the broken needle.
  4. QSEW QS-1201 Needle Replacement: Schritt 4, Bild 1 von 3 QSEW QS-1201 Needle Replacement: Schritt 4, Bild 2 von 3 QSEW QS-1201 Needle Replacement: Schritt 4, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
  5. QSEW QS-1201 Needle Replacement: Schritt 5, Bild 1 von 3 QSEW QS-1201 Needle Replacement: Schritt 5, Bild 2 von 3 QSEW QS-1201 Needle Replacement: Schritt 5, Bild 3 von 3
    • Gently secure the needle with the needle nose pliers.
    • With a tight grip, pull down to remove the needle.
  6. QSEW QS-1201 Needle Replacement: Schritt 6, Bild 1 von 3 QSEW QS-1201 Needle Replacement: Schritt 6, Bild 2 von 3 QSEW QS-1201 Needle Replacement: Schritt 6, Bild 3 von 3
    • Discard the broken needle in a safe place.
    • By doing so, you ensure that no one gets injured when dealing with the trash.
    • Afterward, use the needle nose pliers to insert the new needle into the needle holder securely.
  7. QSEW QS-1201 Needle Replacement: Schritt 7, Bild 1 von 3 QSEW QS-1201 Needle Replacement: Schritt 7, Bild 2 von 3 QSEW QS-1201 Needle Replacement: Schritt 7, Bild 3 von 3
    • Use the 3 mm Flathead screwdriver to secure the screw, without over-tightening.
  8. QSEW QS-1201 Needle Replacement: Schritt 8, Bild 1 von 3 QSEW QS-1201 Needle Replacement: Schritt 8, Bild 2 von 3 QSEW QS-1201 Needle Replacement: Schritt 8, Bild 3 von 3
    • Move the needle using the pliers in a circular motion from left to right to verify it moves freely without hitting any surrounding components.
    • You're all set to use your embroidery machine!
Abschluss
Reema
157 Reputation
1 Anleitung geschrieben
York University, Team 1-28, O'Regan Fall 2023 Mitglied von York University, Team 1-28, O'Regan Fall 2023
YORK-O'REGAN-F23S1G28
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 8
Insgesamt: 278
