Remington MB4040 Blade Replacement
Einleitung
Zu Schritt 1 der AnleitungThis guide will systematically explain how to replace the shaving blade of the Remington MB4040. A rough or irritating shave is most likely caused by a dull blade. The replacement of this dull blade will allow for a more comfortable shave.
Was du brauchst
Werkzeuge
Press the black button to release the blade from its locked position.
Remove the two 8.0 mm PH00 Phillips head screws from the blade assembly.
Detach the silver blade from the blade assembly and replace with the new blade.
