Zum Hauptinhalt wechseln
Remington MB4040 Thermal Switch Replacement
Cameron Carnahan
Cameron Carnahan und 2 weitere Mitwirkende
Zuletzt aktualisiert am July 14, 2024
20 Minuten
Schwierig
Action Shots
The thermal switch allows for automatic shut-off if the battery temperature exceeds a specified limit.
Was du brauchst
Werkzeuge
Mehr anzeigen …
  1. Remington MB4040 Thermal Switch Replacement, Remove Blade Assembly: Schritt 1, Bild 1 von 3 Remington MB4040 Thermal Switch Replacement, Remove Blade Assembly: Schritt 1, Bild 2 von 3 Remington MB4040 Thermal Switch Replacement, Remove Blade Assembly: Schritt 1, Bild 3 von 3
    • Press the black button below the blade to remove the blade.
  2. Remington MB4040 Thermal Switch Replacement, Remove Back Cover Hardware: Schritt 2, Bild 1 von 2 Remington MB4040 Thermal Switch Replacement, Remove Back Cover Hardware: Schritt 2, Bild 2 von 2
    • Place the device so the back of the product is facing up.
    • Remove the two 11.0 mm PH00 screws from the black plastic housing at the bottom of the device.
  3. Remington MB4040 Thermal Switch Replacement, Remove Front Cover Hardware: Schritt 3, Bild 1 von 3 Remington MB4040 Thermal Switch Replacement, Remove Front Cover Hardware: Schritt 3, Bild 2 von 3 Remington MB4040 Thermal Switch Replacement, Remove Front Cover Hardware: Schritt 3, Bild 3 von 3
    • Remove the chrome plated plastic piece by using the plastic opening tool to pry it from the housing assembly.
    • Remove the small clear plastic piece that covers the zoom wheel numbers.
  4. Remington MB4040 Thermal Switch Replacement, Front Cover (cont.): Schritt 4, Bild 1 von 2 Remington MB4040 Thermal Switch Replacement, Front Cover (cont.): Schritt 4, Bild 2 von 2
    • Remove the two 16.0 mm PH00 screws from the front cover.
    • Use the blue plastic opening tool to pry apart the two halves of the device.
  5. Remington MB4040 Thermal Switch Replacement, Blade Button Removal: Schritt 5, Bild 1 von 2 Remington MB4040 Thermal Switch Replacement, Blade Button Removal: Schritt 5, Bild 2 von 2
    • Remove the black blade button and the two 10.0 mm springs, which are sandwiched between the cover assembly halves.
    • The blade button is sandwiched between the halves and the two springs may fall out when the halves are separated.
  6. Remington MB4040 Thermal Switch Replacement, Remove Motherboard: Schritt 6, Bild 1 von 2 Remington MB4040 Thermal Switch Replacement, Remove Motherboard: Schritt 6, Bild 2 von 2
  7. Remington MB4040 Thermal Switch Replacement, Remove Thermal Switch: Schritt 7, Bild 1 von 1
    • Separate the thermal switch from the battery by using a spudger to pry it from the adhesive.
    • Use a low temperature RTV to readhere the thermal switch to the battery.
    • Remove the soldering holding the thermal switch to the motherboard.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
USF Tampa, Team 1-5, Blackwell Winter 2015 Mitglied von USF Tampa, Team 1-5, Blackwell Winter 2015
USFT-BLACKWELL-W15S1G5
3 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 22
Insgesamt: 3,027
