Zum Hauptinhalt wechseln
Replace Apple Xserve 2009 Motherboard and fans
Was du brauchst
  1. Replace Apple Xserve 2009 Motherboard and fans, Xserve 2009 MLB and Fan replacement: Schritt 1, Bild 1 von 2 Replace Apple Xserve 2009 Motherboard and fans, Xserve 2009 MLB and Fan replacement: Schritt 1, Bild 2 von 2
    • Notable specs:
    • Dual Xeon Nehalem CPU @ 2.26 GHz
    • No SSD
    • No Hardware RAID
    Frag FixBot
    Kommentar hinzufügen
  2. Replace Apple Xserve 2009 Motherboard and fans: Schritt 2, Bild 1 von 1
    • Pull on release lever, and pull power supply out.
    Frag FixBot
  3. Replace Apple Xserve 2009 Motherboard and fans: Schritt 3, Bild 1 von 2 Replace Apple Xserve 2009 Motherboard and fans: Schritt 3, Bild 2 von 2
    • Loosen the 2 thumbscrews on the back of the xserve to release the top.
    • Slide top back, and lift top off.
    Frag FixBot
  4. Replace Apple Xserve 2009 Motherboard and fans: Schritt 4, Bild 1 von 1
    • This step is not necessary if you are not changing the drive. It does not interfere with the rest of the procedure.
    • If the hard drives or blanks are still in the xserve, push the handle in to pop it out.
    • Pull the hard drive and blank sleds out.
    Frag FixBot
  5. Replace Apple Xserve 2009 Motherboard and fans: Schritt 5, Bild 1 von 3 Replace Apple Xserve 2009 Motherboard and fans: Schritt 5, Bild 2 von 3 Replace Apple Xserve 2009 Motherboard and fans: Schritt 5, Bild 3 von 3
    • Slide lever lock to release the CD/DVD drive.
    • Slide CD/DVD drive back.
    • Lift drive up and unplug the SATA connector on the back.
    Frag FixBot
  6. Replace Apple Xserve 2009 Motherboard and fans: Schritt 6, Bild 1 von 1
    • Using a #1 Phillips screwdriver, unscrew the screws on each side of PCI slot #2 on the back of the computer.
    • Once the screws are loosened, the PCI riser card should lift out of the slot.
    • Repeat for PCI slot #1
    Frag FixBot
  7. Replace Apple Xserve 2009 Motherboard and fans: Schritt 7, Bild 1 von 1
    • Remove the RAM from all slots.
    Frag FixBot
  8. Replace Apple Xserve 2009 Motherboard and fans: Schritt 8, Bild 1 von 2 Replace Apple Xserve 2009 Motherboard and fans: Schritt 8, Bild 2 von 2
    • Using a 3.0mm Hex wrench (Allen wrench), loosen the 4 screws that hold the processor and heatsink down.
    • Unplug the sensor cable.
    • Lift the heatsink and processor off the motherboard.
    • Repeat if you have the dual processor model.
    Frag FixBot
  9. Replace Apple Xserve 2009 Motherboard and fans: Schritt 9, Bild 1 von 3 Replace Apple Xserve 2009 Motherboard and fans: Schritt 9, Bild 2 von 3 Replace Apple Xserve 2009 Motherboard and fans: Schritt 9, Bild 3 von 3
    • Using a #1 phillips screwdriver, loosen the 5 screws that hold the plastic bezel in place.
    • Remove the plastic bezel.
    • Using a #2 phillips screwdriver, loosen the 2 screws that hold the fan array in place
    • Lift the fan array out.
    Frag FixBot
  10. Replace Apple Xserve 2009 Motherboard and fans: Schritt 10, Bild 1 von 2 Replace Apple Xserve 2009 Motherboard and fans: Schritt 10, Bild 2 von 2
    • Using the spudger, lift the connector on the right.
    • Carefully squeeze the connector on the left and unplug it.
    • Using the spudger, lift the CD/DVD connector by the CPU A RAM slots.
    Frag FixBot
  11. Replace Apple Xserve 2009 Motherboard and fans: Schritt 11, Bild 1 von 3 Replace Apple Xserve 2009 Motherboard and fans: Schritt 11, Bild 2 von 3 Replace Apple Xserve 2009 Motherboard and fans: Schritt 11, Bild 3 von 3
    • Using a #2 screwdriver, loosen the 9 screws that hold the motherboard in place.
    • There are 3 rows of 3 screws each. 1 row by the back of the computer, 1 row in the middle and 1 row by the fan array. They are obvious by the black plastic spacer/retainer on them.
    Frag FixBot
  12. Replace Apple Xserve 2009 Motherboard and fans: Schritt 12, Bild 1 von 1
    • Using a #2 screwdriver, loosen the screw on the power board.
    • Slide it up to disconnect it from the motherboard.
    Frag FixBot
  13. Replace Apple Xserve 2009 Motherboard and fans: Schritt 13, Bild 1 von 2 Replace Apple Xserve 2009 Motherboard and fans: Schritt 13, Bild 2 von 2
    • Remove the 2 screws that hold the video card on.
    • Slide the card out of the socket.
    Frag FixBot
  14. Replace Apple Xserve 2009 Motherboard and fans: Schritt 14, Bild 1 von 1
    • Lift the motherboard and slide it out ofthe connectors on the back of the computer.
    • Then tip the motherboard up and out of the computer.
    Frag FixBot
Abschluss
18 weitere Personen haben diese Anleitung absolviert.
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 52
Insgesamt: 12,591
