Zum Hauptinhalt wechseln
Samsung Galaxy Camera Capture button Replacement
Richard Hicks
Richard Hicks und 6 weitere Mitwirkende
Zuletzt aktualisiert am July 1, 2024
30 - 35 Minuten
Mittel
Action Shots
Fehler in den Markups
Fehlende grundständige Anleitungen
Bessere Einleitung
Was du brauchst
Werkzeuge
  1. Samsung Galaxy Camera Capture button Replacement, Screen: Schritt 1, Bild 1 von 1
    • Begin removing the 3/16" screws for the device.
  2. Samsung Galaxy Camera Capture button Replacement: Schritt 2, Bild 1 von 1
    • Turn the device and remove the additional 3/16" screws.
  3. Samsung Galaxy Camera Capture button Replacement: Schritt 3, Bild 1 von 1
    • Turn the device and remove the additional 3/16" screw.
  4. Samsung Galaxy Camera Capture button Replacement: Schritt 4, Bild 1 von 3 Samsung Galaxy Camera Capture button Replacement: Schritt 4, Bild 2 von 3 Samsung Galaxy Camera Capture button Replacement: Schritt 4, Bild 3 von 3
    • Take the white cover plate off.
  5. Samsung Galaxy Camera Capture button Replacement: Schritt 5, Bild 1 von 1
    • Using the plastic opening tools, pry open the camera from the bottom.
    • This may require a moderate use of force because of the sealing glue.
  6. Samsung Galaxy Camera Capture button Replacement: Schritt 6, Bild 1 von 1
    • Gently pull the connector away from the motherboard.
  7. Samsung Galaxy Camera Capture button Replacement, Lens and Motherboard: Schritt 7, Bild 1 von 1
    • Unscrew the motherboard's screws. There are 4 3/32" screws and 3 5/32" screws.
  8. Samsung Galaxy Camera Capture button Replacement: Schritt 8, Bild 1 von 1
    • Unscrew the lens' screws. There are 1 black 4/32" screw, 3 3/16" black screws, and 2 white 5/32" screws.
  9. Samsung Galaxy Camera Capture button Replacement: Schritt 9, Bild 1 von 1
    • Pull these connectors away from motherboard.
  10. Samsung Galaxy Camera Capture button Replacement: Schritt 10, Bild 1 von 1
    • Lift the motherboard and lens out of the case.
  11. Samsung Galaxy Camera Capture button Replacement, Unscrew: Schritt 11, Bild 1 von 1
    • Remove all the screws circled. There is 1 1/8" screw by the flash, 1 9/32" screw that holds the flash button, 2 5/32" screw that is on the grey frame for the flash, and 2 5/32" screws that holds the cable frames on the top left.
  12. Samsung Galaxy Camera Capture button Replacement: Schritt 12, Bild 1 von 1
    • Unscrew the 3 5/32" screws that cover the battery plate.
  13. Samsung Galaxy Camera Capture button Replacement: Schritt 13, Bild 1 von 1
    • The black plates on the other side can be removed after these screws.
  14. Samsung Galaxy Camera Capture button Replacement: Schritt 14, Bild 1 von 1
    • Pull the flash and battery case out of the device.
  15. Samsung Galaxy Camera Capture button Replacement, Capture button: Schritt 15, Bild 1 von 1
    • Unscrew the 2 5/32" screws on the grey plate.
  16. Samsung Galaxy Camera Capture button Replacement: Schritt 16, Bild 1 von 1
    • Pull the plate aside and unscrew 2 1/8" screws on the button.
  17. Samsung Galaxy Camera Capture button Replacement: Schritt 17, Bild 1 von 1
    • The Capture button can now be removed.
Abschluss
10 weitere Personen haben diese Anleitung absolviert.
Richard Hicks
1.280 Reputation
4 Anleitungen geschrieben
USF Tampa, Team 1-3, Sullivan Winter 2015 Mitglied von USF Tampa, Team 1-3, Sullivan Winter 2015
USFT-SULLIVAN-W15S1G3
3 Mitglieder
6 Kommentare
Thank you very much for these instructions - they enabled me to fix the camera after four repair places refused to.
(the two screws holding the shutter button in place had come loose - the button had fallen off and the loose screws inside were interfering with the zoom switch, sending the camera always to safe mode)
A couple of things: It is not necessary to remove the black screws at step 8. They hold something in place in the lens assembly, but don't prevent you from moving to step 10. Also, it is not necessary to remove the screws at step 11 - only the leftmost one in the image. If you are careful of the wires, the battery case can be folded back giving adequate access to the shutter assembly.
Also - when reassembling, be careful at step 17 that the zoom lever is positioned to be engaged with (hooked over) the lever on the brown circuit board.
danridleyellis - Antwort
It's a good and detailed instruction, but it also has mistakes (see my comments to steps 8, 11 and 15).
NOVOMOTION J. H. - Antwort
Thank You so much for the help! I would have never been able to replace the button without these instructions. You are a lifesaver.
Karen Rose - Antwort
Dis assembly has been educational and all ,but where do I get my new button???????
Paul Rice - Antwort
I realize the I wouldn't have been able to get this camara apart without the instructions. Very helpful and I do thank you Mr. Hicks. But I didn't want to take it apart. I want to fix it… and put it back together….and use it…perhaps just maybe take a photo or two. So please may I ask for information on obtaining a replacement capture/ zoom button assembly/ parts?????
Paul Rice -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 35
Insgesamt: 2,714
